How To Remove Caliper Piston......
Old May 24, 2009 | 08:04 PM
Richard Cooper's Avatar
Richard Cooper
Default How To Remove Caliper Piston......
I am having my calipers powder coated and need to take them apart to do so. I have them in half and just need to remove the 4 pistons. This is on my 81. Around the outer bore of the caliper there looks to be a small brass ring. Then there is a rubber boot and in the middle there is a round piece of steel that pushes against the pads. I am not sure how to remove the pistons, I do not care if the boots get ruined because I plan on re-building the whole caliper when they are done. Thanks for any help in this matter.
Old May 24, 2009 | 08:23 PM
72LS1Vette's Avatar
72LS1Vette
The outer seals are not held in very tightly. You can use something like a small screwdriver to slide down between the piston and the seal and pry up gently under the outer portion of the seal. It should pop out easily without causing any damage.
Rick B.
Old May 24, 2009 | 09:47 PM
Richard Cooper
Thanks Rick, I will try that tomorrow.
Old May 25, 2009 | 09:14 PM
GUSTO14's Avatar
GUSTO14
If you have the caliper halfs apart, the easiest way is to lay them on a block of wood and shoot some air into the brake line hole in the caliper half. Be sure you have the bleeder in and tight so there are no leaks. On the other half (with only a bleeder in it), use the bleeder opening. Laying them on a block of wood will restrict the cross caliper passage enough to let the air pop the piston out.
I would turn your air pressure down a bit and keep your hands away from the pistons because they will pop out (with the outer seal) with some force. If both pistons don't come out initially (one will definitely pop) stuff a rag into the now open bore and shoot some more air into the caliper and the other will pop out.
Just be careful because they will pop out with force.
Good luck... GUSTO
Old May 25, 2009 | 10:19 PM
AeroDog's Avatar
AeroDog
From: Carolina raised but in Loveland CO for tha duration
Easy. Slide a screwdriver radially outward from the center until the blade goes under the inner lip of the metal ring. Pry upward with the blade, popping the metal ring out (with attached rubber dust cover). The piston should come right out. If it's reluctant to come out -- if it has been sitting a long time -- grasp it lightly with pliers and pull. If it has been sitting a long time, soak it with brake fluid.
Old May 26, 2009 | 09:04 PM
depdep3's Avatar
depdep3
I am doing the same job in a week or so. Any trick to getting the pistons back in the calipers?
Old May 26, 2009 | 09:10 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Just be careful when you use a screwdriver to get the outer seal out. Do not let the screwdriver score the piston bore. It could mean buying new calipers again.
Old May 26, 2009 | 09:19 PM
GUSTO14's Avatar
GUSTO14
There really is no trick to it... Insure the seal is on the piston, (lip seal or o-ring) then place the outer seal (the one with the retainer attached) over the piston and slip the assembly into the piston cavity. If you are going to use the springs, be sure they are installed behind the piston correctly as you insert the piston into the bore. Then using a large socket (one that covers the metal retainer) and gently tap the retainer into the bore. Once the retainer is seated, just move to the next piston and repeat the procedure.
When both halfs are assembled with pistons, join the two halfs together and insert the bolts. There is a small o-ring seal between the two caliper halfs that must be placed correctly before joining the two halfs. There is a cavity in one of the halfs that the o-ring sits in so it is not difficult to keep it in place while you join the two halfs.
I tighten the two bolts snugly, but wait until the caliper is mounted to make it easier to torque them tight.
Good luck... GUSTO
Old May 26, 2009 | 10:22 PM
AeroDog's Avatar
AeroDog
For what it's worth, I upgraded to calipers sleeved with stainless steel 23 years ago and the bores still look new. Absolutely no pitting or corrosion. You may consider upgrading to o-ring pistons if you haven't done so.
Old May 26, 2009 | 11:44 PM
72LS1Vette's Avatar
72LS1Vette
Good luck... GUSTO
I think this technique works with an O-ring seal but I disagree about just pushing the piston into the bore with a lip seal. I tried that with one of my pistons and the seal flipped inside-out. It goes into the bore but it is oriented the reverse of the way it should be. I found I had to use a piece of wood ( my wife had some cuticle pushers or some dang thing that had a softly pointed/flattened end) to gently push the edges of the seal into the bore (lubed with brake fluid) as I worked the piston in so that the seal maintained it's correct orientation. The next time I rebuild the calipers I'm going to use O-ring seals.
Rick B.
Old May 27, 2009 | 06:13 PM
GUSTO14's Avatar
GUSTO14
Rick B.
Good point Rick...
With a lip seal, I do get the seal wet with brake fluid as well as the inside of the bore. Then while inserting the piston, I gently twist the piston as I push it in. The twisting motion and wet bore have always worked to get them in without turning them inside out. The secret to success I believe is getting it started in the bore carefully and correctly.
Good luck... GUSTO
To How To Remove Caliper Piston......
