Top of the weekend to you all. I am in the frame off process with a 69 coupe. I am replacing all of the rubber suspension bushings with either original or poly (not sure yet). During my search for bushing kits that will include everything I need, I found there are various sizes for the front sway bar. The ones I've seen are 1", 1 1/8th" and 1 1/4."
I plan to just pleasure cruise this car on weekends but you all know there may be a temptation for an autocross or two down the road. I would like it to have a decent ride but still be stiff enough to prevent yawing around corners.
Is this a classic case of bigger is better or is there such thing as overkill when it comes to the sway bar?
I probably would stay around 1". Bigger front bars induce more understeer (front end "push"), something you're likely to encounter at the "occasional" autocross, and the bigger bar will make it worse. I think the stock bar is 3/4" or 13/16", so a 1" or 1-1/8" bar will be an upgrade for keeping the body flatter in corners in spirited street driving.
Usually, depending on the car itself, ride hieght, ect. A thicker front bar
reduces oversteer and increases understeer. The same result can be had by lowering tire air pressure in the front and increasing it in the back. The opposite to reduce understeer and increase oversteer.
Every peice of the suspension works together, dialing in a suspension takes time and trial and error, If your only going to autocross occassionally, just change tire pressures, it's easier and a lot cheaper.
Hey everyone, thank you for all of your input. From what I'm hearing then is just stick with stock and rubber at that (for the most part). I again thank you all for saving me some cash that I can now put elswhere on the car. You know how that goes.
From: Graceland in a Not Correctly Restored Stingray
For future reference...
When you DO get to the point where you're ready to improve your cornering capabilities, just remember the solution to the puzzle involves considerably more than simply increasing roll resistance with more bar, so I'd suggest that you not make any changes before determining precisely what you want/need to improve about your car's handling characteristics. Then you'll be better equipped to decide how to spend your $$$ wisely and end up getting positive results without nearly as much trial and error (there'll still be room for plenty of that). Same goes for anyone who doesn't understand more than "I want my car to handle better". And, there's no substitute for testing. My $.02
TSW
