An alarming situation
Old May 25, 2009 | 07:20 PM
lock-n-load's Avatar
lock-n-load
Default An alarming situation
What is the correct procedure for setting the alarm on a '75 ?
When i try to set it using the key slot in fender, the alarm sounds continuously untill i turn it off ...
I seem to remember reading about t-top switches and door locking procedures in later C-3's ... but not sure if that setup would be the same for my car .....Any help?
Old May 25, 2009 | 07:29 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Your working the switch correctly some switch is not working properly.
You only have a few switches to check on this car, alarm cylinder theft switch (inside the fender), the hood switch and two door jamb switches. All the switches pretty much will fail over time so start with each switch and then try the car.
The hood switch mounted on a bracket at the firewall was always one that I checked first. The hood seems to bend the bracket sometimes and the switch will not collapse the switch when the bracket is bent.
The switch on the back of the alarm switch is another common one due to the way this switch is made. It’s plastic and will come apart on you! Make sure it has not self destructed.
Then go to the two door alarm switches.
You do not have T-top switches on your car, this did not start until 1978.
Willcox Inc.
Old May 26, 2009 | 09:40 AM
Willynojob's Avatar
Willynojob
Thank you, I need to do this to my 76 which has the same problem.
Old May 26, 2009 | 08:43 PM
lock-n-load
Glad to know im not the only one ....
Please let me know if you corrected the problem ..
thanks
Dean
To An alarming situation
