75 Convertible Door Sagging fix
Old May 27, 2009 | 02:43 PM
maustin26's Avatar
maustin26
3rd Gear
Default 75 Convertible Door Sagging fix
It is inevitible; C3 convertible doors are going to sag. Question is, if one was to get the kit offered by one of the mail order parts houses, how difficult is this job? Let's just assume a basic skill level here.
Old May 27, 2009 | 06:13 PM
Alan 71's Avatar
Alan 71
Are the doors sagging because of worn out hinges? Or is there some other trouble?
If it's the hinges, it a pretty straight forward fix. I think the biggest thing is to have a way to support the weight of the door while you're changing the bushings and pins.
Then you'll probably need to adjust the hinges to get the door gaps even again. This can take some tme and patience.
Regards,
Alan
Old May 27, 2009 | 08:49 PM
crazywelder's Avatar
crazywelder
If the hinge bushings are worn, here's how I do them. Hopefully you have a helper to assist in holding the door while you remove it. Use a floor jack to support the door while you unbolt it and remount it. You can make a wood trough about 24" long wrapped with a towel to place on the jack to protect the bottom of the door. Wrap the front of the door with a towel also. The main concern is protecting the paint on the front and bottem of the door. Remove the inner door trim and spray the 4 upper and 4 lower bolt heads with spray paint to mark there position on the door shell for easy alignment when you reassemble it. Slide the door off the hinges. You can change the lower hinge bushings and pin on the car without removing the hinge, but you'll need to remove the upper hinge. I have a jig that I clamp to the cowl to make reinstalling the upper hinges in the same place easy every time. Replace the upper springs while you are at it.
If your bushings are shot your rear door guide bushings are probably worn out also and might need to replace them as well.
Old May 28, 2009 | 11:33 AM
maustin26's Avatar
maustin26
3rd Gear
Thanks Alan, I am emboldened. I have an 8 year old grandson who wants to help but I think I will get a little more horsepower to do the job. BTW, that is sure some meat eating animal behind you in the picture. Thanks again. Mel
Old May 28, 2009 | 06:23 PM
Alan 71's Avatar
Alan 71
Hi Mel,
That's a picture I took in 1993 of Zora and the real GS 001.
Quite a pair!
Regards,
Alan
Old May 28, 2009 | 10:01 PM
bluegoosed's Avatar
bluegoosed
Since I have been on here I always thought that was you and your car in the picture. Neat! I never had a clue.
Old Jul 24, 2011 | 10:58 PM
rafalc's Avatar
rafalc
Regards,
Alan
What if the door is sagging but there is no play when picking the rear of the door up? Could this still be the hinges or should you see some play?
Old Jul 24, 2011 | 11:57 PM
bryanpl123's Avatar
bryanpl123
I just found when I removed my door that the top part of the bird cage where the door hinge was bolted to was bent out about 1/4" right around the bolt hole... possibly from someone leaning on an open door... so definatly check your mating surface for deformity.
To 75 Convertible Door Sagging fix
