Dewitt Radiator Question?
Old May 29, 2009 | 11:56 PM
KW's Avatar
KW
Default Dewitt Radiator Question?
Got my Radiator with the fans installed,
direct fit for a 71 auto, tried to set it in place
the electric fan housing is getting hung up on the A-arm
Do i need to remove the radiator support, or lossen it
attach the radiator then tighting up the support
or is there some way I'm not holding my mouth right
any help would be nice
Thanks KW
Old May 30, 2009 | 07:11 AM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
You could remove the fans from the radiator and install the radiator first, then re-install the fans onto the radiator. To remove the fans, remove the six philips head screws on the top and bottom channels. Do not remove the hex bolts, this will just complicate things. When re-installing the fans, you can use the existing screw holes but if the fans need to be re-centered between the a-arms, you can drive the self tapping screws in anywhere in the hollow channels.
Old May 30, 2009 | 08:48 AM
Gordonm's Avatar
Gordonm
I had the same problem and as Tom suggests this works fine. Just slightly relocate the fans.
Old May 30, 2009 | 08:51 AM
KW's Avatar
KW
Tom
thanks I will try that today
and thanks for a great looking set up
KW
Old May 30, 2009 | 09:01 AM
mrvette's Avatar
mrvette
Originally Posted by KW
Tom
KW
Make sure you got them hanging right, flaps hinged on TOP....and they will cool like MAD....
Old May 30, 2009 | 01:43 PM
Rickman's Avatar
Rickman
I just love this. Here a CF Member has a problem/challenge w a part ordered from a Supporting Vendor. He gets a personal response from the vendor within 12 HOURS, where the vendor offers his help and a solution.
I hope this never changes. By this I mean with all the challenges we are facing in the U.S. right now, the demise of GM, the daily dismantling of our nation by an administration that promised to UPHOLD the U.S. Constitution, etc......
I am proud to be a Christian, a husband & father, an American, a Corvette owner, and a CF Member.
Rickman
Last edited by Rickman; May 30, 2009 at 01:48 PM. Reason: not finished, hit wrong key
Old May 30, 2009 | 10:56 PM
KW's Avatar
KW
Just wanted to say Thanks again
Tom you the Man
heres a pic. of the Dewitt installed and a March system
still have a lot of fine tuning to do
hope to have it going soon
Old Jun 2, 2009 | 03:31 PM
HUSKER-Z's Avatar
HUSKER-Z
Looking to get into a dewitts radiator/ dual spal set for my 76.... does dewitts ever do blowout sales or group purchases?
Old Jun 2, 2009 | 06:02 PM
houstonvett's Avatar
houstonvett
St. Jude Donor '09, '24
Old Jun 2, 2009 | 06:29 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Originally Posted by houstonvett
I was just asked the same question on the DC forum. My answer was not right now because we are going to Bloomington Gold with show specials and then Corvette@Carlisle eight weeks later. I feel we have to stick to this summer rule to keep car show alive. If you can shop for everything on the internet, these events will completely die out.
To Dewitt Radiator Question?
