Per the NCRS Judging Guide, I decided to put Trico wiper blade holders on my 1973. The blade inserts, which are the correct 16" length, now stick out from the holder about 1/4"-3/8" on each side. The "incorrect" blade holders (didn't say Trico) I removed from the car were longer and seemed to fit the inserts better. It's a Top Flight car, so I want it original, but something doesn't look right with the Trico's:
Hi SD,
On my 71, original holders and blades, the end of the blade that the prongs on the holder clip into, stick out from the end of the holder about 3/8". The other end of the blade and holder are almost flush with each other.
Regards,
Alan
Hi SD,
Regards,
Alan
Here are the blade holders that I took off the car. They differ from the Trico's I bought in that they're longer and have a tab on the tips
There's no manufacturer's name on them. Just a number stamped inside one of the small arms
"185" is stamped inside one of the small arms of each blade holder where I'm pointing
