68 inside door pull handle??
Old Jun 3, 2009 | 05:12 PM
durnincorvette.com's Avatar
durnincorvette.com
Default 68 inside door pull handle??
hey guys! i have a 68 here that needs new door panel but the weird thing is that i only have one door pull handle (honrizontal type btw)and its on the passenger side.
question is should i have two? one on each side or was it installed only on the passenger side?
thanks a lot
pat
Old Jun 3, 2009 | 05:58 PM
dbeall1968's Avatar
dbeall1968
What is your build date? Early 68s had a molded in pull, later were like the 69s. Your pass. door sounds like a 69. I don't know the cut-off date for the change, but I am sure someone here does.
Old Jun 3, 2009 | 06:29 PM
682XLR8's Avatar
682XLR8
My 68 is late and has a pull handle on each side
Old Jun 3, 2009 | 07:42 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
[QUOTE=dbeall1968;1570319393]What is your build date? Early 68s had a molded in pull, later were like the 69s. Your pass. door sounds like a 69. I don't know the cut-off date for the change, but I am sure someone here does. [/QUOTE
early 68's had no pulls (just the one under the top of the panel if that's what you meant), later 68's added (each side) horizontal pulls added (which were not molded in).........no 68's had the 69 verticals, the whole door panel including thickness, was redesigned for 69.
Old Jun 3, 2009 | 08:09 PM
7T1vette's Avatar
7T1vette
Old Jun 3, 2009 | 09:54 PM
dbeall1968's Avatar
dbeall1968
Yeah, Iwas speaking of the molded pull. Didn't the 69 design give more interior room (less protrusion towards the seats)?
Old Jun 3, 2009 | 10:06 PM
53 Blue Flame's Avatar
53 Blue Flame
[QUOTE=avalonjohn;1570320587]
Correct. The horizontal pulls are the same for the deluxe Camaro interior cars, 1969 for sure.
To 68 inside door pull handle??
