Steering column conversion old to newer?
Old Jun 7, 2009 | 10:51 AM
1970-Bronze's Avatar
1970-Bronze
Default Steering column conversion old to newer?
Does anyone have a photo of the lower trim piece that needs to be trimmed?
Thanks....
Old Jun 7, 2009 | 11:03 AM
Duke94's Avatar
Duke94
Thanks....
I'd like to see it too. I bought a couple of junk 76' T/T columns off eBay and made one good one. I had no trouble bolting it in to my 71' Vert and didn't modify anything other than to buy a later year hub so I could use the 78' style 14" wheel. Did I miss something?
Gary
Old Jun 8, 2009 | 09:32 AM
1970-Bronze
No one?
Old Jun 8, 2009 | 11:18 AM
72LS1Vette's Avatar
72LS1Vette
Here is a pic of a column after it was trimmed. You just have to cut 2.25" (a bit more according to Jim Shea's paper but this worked for me) off the end of the housing, taking care not to cut the wires or the dimmer rod.
Rick B.
Old Jun 8, 2009 | 11:23 AM
Duke94's Avatar
Duke94
I see why mine worked, I used a 76' column and it appears that the column changed in 77'. Guess I got lucky as I did this conversion before Jim's paper.
Gary
Old Jun 8, 2009 | 12:43 PM
70BBvert's Avatar
70BBvert
I did a comparison, last year here:
http://forums.corvetteforum.com/c3-g...of-a-70-a.html
Jim
Old Jun 8, 2009 | 03:35 PM
Ganey's Avatar
Ganey
Gary
Gary
77 bolts into earlier, remember the groups 68-77 & 78-82. The column change that is the issue was in 78.
If I had bought an earlier model, I would have changed columns in the 70s.
Old Jun 8, 2009 | 04:38 PM
Jim Shea's Avatar
Jim Shea
The dash changed in 1978. That is one reason why the 1977 column is a one year only design. It should pretty much bolt right into a 1969-76 without much trouble. This is what I had figured on how you would have to modify the plastic shroud on a 1978-82 column by cutting it off to the indicated dimension.
Jim
Old Jun 8, 2009 | 10:08 PM
1970-Bronze
Ok, it makes more sense now.....I thought I had to trim the dash.
Thanks All.....
To Steering column conversion old to newer?
