Temp rising... help
Old Jun 11, 2009 | 09:05 AM
sixxgunn13's Avatar
sixxgunn13
Default Temp rising... help
Changed my water shut off valve last weekend, yesterday I was driving home after work and the temp goes to 220-240 and a bit into the red... I pulled over to let it cool, then drove home. today driving to work the same happens... any ideas? I will check the coolant at break, and oil.
help!!
Old Jun 11, 2009 | 09:55 AM
...Roger...'s Avatar
...Roger...
help!!
Given what you changed it sounds like your low on coolant in the radiator. Make sure the tube in the coolant recovery tank is there.
Old Jun 11, 2009 | 12:37 PM
DaJesterMan's Avatar
DaJesterMan
also, ensure there is not an air bubble in the thermostat housing that could be blocking the coolant...
Old Jun 11, 2009 | 01:30 PM
sixxgunn13's Avatar
sixxgunn13
Thx guys..
it look to be a tad bit low on coolant.
I thought I added enough.
Old Jun 11, 2009 | 02:14 PM
2box's Avatar
2box
What would be the right amount of coolant? I kind of have the same problem and I want to make sure.. Thanks
To Temp rising... help
