You just slide the panel up and behind the actuator. You need to have the door sill plate removed and the right side dash pad screws out of the end at the door.
If your aftermarket panel need to be machined for additional clearance, just use a little cut-off wheel on a Dremel and make clean cuts. I'm not so sure that the factory (or their supplier) didn't do just that for the A/C pieces.
