Radio
Old Jun 15, 2009 | 08:10 PM
javaman's Avatar
javaman
2025 C6 of the Year Finalist - Modified
2021 C6 of the Year Finalist - Modified
Default Radio
My 69 coupe (just purchased from someone who did not know too much about this car) has a stock Delco AM-FM radio. That's the good news. The bad news is it does not work. I would rather not switch out the radio even if keeping it means poor audio. Of course, right now nothing is coming through and no audio is much worse than poor audio. Repair/ troubleshoot suggestions?
Old Jun 15, 2009 | 09:15 PM
wer2xu's Avatar
wer2xu
http://www.wardsclassiccarradiorepair.com/id2.html
150 bucks, and your radio is like new. about 2-3 week turn around time. These guys father/son do great work.
your speakers may need to be reconed as well.
Old Jun 16, 2009 | 02:31 AM
c3_guy's Avatar
c3_guy
When I bought my 76 the radio didn't work. I did a little looking around under the dash and found the amplifier wasn't hooked up to the radio. Apparently the former owner had removed an after market stereo and put the original back in and didn't know what he was doing. Once I reconnected the amp everything worked fine or at least as fine as the stock radio can work. I don't know much about your year, but check to be sure it is wired in correctly.
Old Jun 16, 2009 | 06:31 AM
javaman's Avatar
javaman
Thank you both for your replies. I checked out Wards and if it is not something (very, very) simple when I look under the dash I will send the radio out to them.
Old Jun 16, 2009 | 11:34 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
GM calls this a convector. One for mono.
Two for stereo.
Check to see if your original is up under the dash, passenger's side.
Old Jun 16, 2009 | 12:04 PM
7T1vette's Avatar
7T1vette
First, check to see that the antenna system is in good order and connected at the radio. Next, verify that you are getting power to the radio and that the speaker wires are not cut. Lastly, remove the right side dash panel; then remove the 'convector' [final amplifier stage for the radio] and unplug it from the radio head. You can easily test the power transistors (one for AM/FM; two for stereo system) with a volt-ohmmeter {search the web for instructions on doing this}. If you have a bad power transistor, replace it and see if it works. If none of that solves your problem, have the head unit checked/repaired as mentioned above.
Old Jun 16, 2009 | 12:11 PM
Muddywaters's Avatar
Muddywaters
I know of an ex forum member that has a (I believe) new stock radio for sale. He never installed it, found out...the problem actaully was his speakers. He sold the 73 and is now cleaning out the garage. PM me for info...Muddy
Old Jun 16, 2009 | 02:04 PM
javaman's Avatar
javaman
Thanks Muddy. Do you know if there is any difference between the 69 & 73 radio?
Old Jun 16, 2009 | 06:45 PM
wer2xu's Avatar
wer2xu
there is, the 69 radio has green lettering, the 73 is white. The ***** are different as well, but interchangeable...and the 69 radio has long leads for the speakers in the kick panels...not sure if 69 has kick panel or dash mounted speakers...
Old Jun 16, 2009 | 08:00 PM
7T1vette's Avatar
7T1vette
The '68 & '69 C3s had the speakers behind the kickpanels; following years cars had them in the dash (only). Sometime in the later '70s, the speakers in the back were added.
Old Jun 16, 2009 | 08:20 PM
javaman's Avatar
javaman
Man, I am embarrassed by how much knowledge you guy's have and how much I don't. Glad to be a member of this forum and will make a donation to help support it. Thanks again to all.
Old Jun 16, 2009 | 09:38 PM
Muddywaters
Looks like the boys have answered your question Muddy
To Radio
