4spd fluid?
Old Jun 28, 2009 | 01:38 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Originally Posted by mrvette
Years ago when I had my Muncie, I switched to 30 wt synthetic engine oil.....the shifting improved a LOT, smooth as silk,
I made the switch when finding out that new stick shift trannies were using ATF in them,
Gene,
Appreciate that you made the leap of faith to synthetics, but I'd still recommend a fluid such as the AMSOIL Manual Syncromesh Transmission Fluid (5w30) (product code MTFQT) mentioned above. Right viscosity for your tranny, but also with the right additives. Engine oils have additives that tranny fluid doesn't need to combat the combustion byproducts in the engine oil, and it has other additives that help combat the high shear forces found in a tranny.
Although I'm lurking down here, my 02 Z06 and my 06 CTS-V (both Tremec six speeds) came with factory fill Dexron III, a mineral oil basestock ATF. I've been running synthetic ATF in both for years.
As an indication of why I think synthetics outperform mineral oil based fluids, compare the rapid shear down low of grade on the factory fill in my CTS-V to the shear stability of the AMSOIL ATF I replaced it with:
2006 Cadillac CTS-V Used Oil Analysis Dexron III vs AMSOIL ATF Transmission Fluid
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jun 28, 2009 | 02:42 PM
7T1vette's Avatar
7T1vette
Yep. I think it was '03 when Corvette went to synthetic oils across the board.
Old Jun 28, 2009 | 02:48 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Originally Posted by 7T1vette
That's right guys. These 'new fangeled' things could be a pig-in-a-poke. I mean, microwave ovens, cell phones...they could give you cancer, right? My gosh, using synthetic oils is like playing with fire . Of course, about every manufacturer of a well-made vehicle puts synthetic oils in now. The others would too [because they know they are that much better], but they're savin' money. Well, stick with your 38 year-old experience and the rest of us will live in the 21st century.
Since you are trying to elicit a response I'll bite I'm really not resistant at all to new technologies. I use synthetics in my C5 and C6 because they were designed for it. I'll stick with what has proven to be reliable for me and many others in my older Corvettes.
I am not trying to impose my beliefs on anyone. I simply responded to the OP question and gave him my well tested opinion of 38 years in duration. If you want to use synthetics it won't bother me. I even run an IPOD in my new Vette
Old Jun 28, 2009 | 08:55 PM
7T1vette's Avatar
7T1vette
Okie-dokie. But, engines haven't been designed to be compatible with synthetic oil. Synthetic oils were designed to be better lubricants for all engines. Once the formula for synthetic oil was developed and proved to be so much better than organic oil (for engine life..thus, for warranty reduction) most all manufacturers jumped on the 'bandwagon'--so they could SAVE MONEY on their warranty claims. {Gee. Not a purely altruistic purpose in their madness.} Anyway, except for not having an adequate level of zinc needed for a few high-load, flat-tappet engines, synthetics are good for just about any mechanical device requiring oil. There are companies even adding the zinc so old farts like us can use it in their high compression, high performance, high revving 38 year old Chevy engines.
Old Jun 28, 2009 | 10:44 PM
PRNDL's Avatar
PRNDL
Jeff, thanks for the refresh!
This additional additive can cause problems with yellow metals like brass or bronze.
My guess "copper" was close, but wrong..
That issue as I recall, is the potential problem with using sythetic oil in an old muncie. I don't know what brass parts are used inside a muncie and I don't know what "problems" are caused by the oil. It might take a long time for the brass to do whatever it does.
Old Jun 29, 2009 | 12:13 PM
Jeff_Keryk's Avatar
Jeff_Keryk
A little clarification: The issue has nothing to do with mineral based vs. syhthetic fluids. It has to do with the specification. GL-4 spec is for synchro transmissions with yellow metals. GL-5 is for hypoid gears and has a higher sulpher content. My understanding is the high sulpher content can be harmful to the yellow metals. The opposite is true also, do not use GL-4 in applications requiring GL-5 spec fluids.
Old Jun 29, 2009 | 04:50 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
George Solich, chief engineer at www.autogear.net, who designed the Autogear Muncies with the Supercase, etc, says to NOT use synthetics in Muncies. The synchros simply do not behave as designed and can hurt shifting performance. He recommends a 80w-90 mineral gear oil with the MT-1 sub-spec which he says is good for the yellow parts. Valvoline fits the bill:
http://www.valvoline.com/products/co...il/gear-oil/61
This is a GL-5 spec'd gear oil. Years ago, GL-5 was thought to corrode yellow parts at twice the normal rate. The modern GL-5 recipes addressed that problem and are now a recommended replacement for GL-4 which is largely unavailable. Google "API-GL4 and API-GL5" for more info about cross compatibility.
Also, if you wish to speak to George Solich give him a call,..good guy:
www.autogear.net
Old Jun 29, 2009 | 05:03 PM
Mike Ward's Avatar
Mike Ward
Uhh, ya they were. The ZR-1 engine was the first GM engine I know of that was designed around the properties of Mobil1. Had their been no synthetics availabel and oil cooer would have been required.
I'll tell ya another fact- the design requirement had NOTHING to do with lubrication.
Old Jun 29, 2009 | 05:11 PM
PRNDL's Avatar
PRNDL
ok, gotit, so it is the GL-5 additives (sulpher?) that is bad for the brass parts (aka yellow metal), but that would be the old GL-5 spec. The new GL-5 spec is ok. Taking all that into consideration, I think I am going to use 100% pure virgin olive oil in my transmission.
Old Jun 29, 2009 | 09:44 PM
7T1vette's Avatar
7T1vette
Man, the immense knowledge around here is just staggering....
Synthetic oils have been around since the early 1940's. They were invented by Germans for use in Panzer tanks because the hardware just wouldn't survive with organic oil products. All engine/tranny manufacturers would have switched over years ago...but the cost difference was too great. Since the 1980's...when the Japanese started developing very small, powerful, hot running engines, synthetic oils have been the saviour of many auto warranty programs. Now that synthetics have proved their value, designers are building engines that can push the limits of metal-on-metal action; thus, the Z06 engines [et al]. That doesn't mean that older engines can't use synthetics "because they weren't designed for it" ; in fact, those engines will be much better off...live longer, run cooler, use less fuel, yada, yada. Oh well, we shouldn't let facts get in the way of someone else's "knowledge".
Old Jun 30, 2009 | 11:06 AM
73, Dark Blue 454
7T1vette. Synthetics are generally better lubricants than petro-based oils; nobody has argued otherwise. But in some applications, the very properties that makes synthetics better (more slippery) is the reason mineral lube is often the recommendation. For our old Muncie transmissions, mineral lube is recommended to ensure proper operation of the synchros. Again, the Chief Engineer at Autogear says to not use synthetics in a Muncie because it could hurt shifting performance. Trust me. George knows what he's doing.
For our old differentials, Eaton, Auburn, and Dana/Spicer, the three giants in the industry, all recommend AGAINST the use of synthetics for their limited slip carriers.
http://www.eaton.com/EatonCom/Produc.../FAQ/CT_128414
http://www.auburngear.com/aftermarke...6pagesize%3d20
(click on "limited slip" above then scroll to "Important Lubrication Note")
http://www2.dana.com/pdf/5323.pdf
(See top of page 3 above)
So, to say carte blanche, that synthetics should be used in place of mineral based petro lube in all cases, would be very poor advice.
Old Jun 30, 2009 | 12:12 PM
Aruba1's Avatar
Aruba1
What is the oil capacity for the 4 spd tranny?
Old Jun 30, 2009 | 01:06 PM
  #33
68 NJConv 454's Avatar
68 NJConv 454
I don't remember the exact capacity but rule of thumb that I go by is to fill it until you feel liquid when you stick your pinky in the fill hole.
Make sure the tranny is sitting level.
Old Jun 30, 2009 | 06:23 PM
  #34
corvetteload's Avatar
corvetteload
Originally Posted by earthquake68
Plain Jane 80W90 Castrol in my M-20. That's all that was ever intended to go in it, so that's what is in it. Don't over think it.
With you on this one quake, the problem is everybody "thinks" they know better than what is meant for these gear boxes.............
Old Jul 8, 2009 | 04:10 PM
  #35
68 NJConv 454
I went with Valvoline 80w90 from Jeggs ($9.99 each)
I'll let you guys know how much capacity it takes.
Thanks for the discussion!
Old Jul 8, 2009 | 04:43 PM
  #36
PRNDL's Avatar
PRNDL
according to my user manual pg 66 capacities:
4spd trans 2 1/2 pts US, 2 pts Imperial, but it doesn't say how much synthetic oil to put in.
and 2 pts is a quart... so I am guessing a bit more than 1 quart.
Old Jul 9, 2009 | 12:49 PM
  #37
jordan89's Avatar
jordan89
It took two quarts of Castrol 80w90 high performance gear oil to fill my 4sp.
Old Jul 9, 2009 | 01:31 PM
  #38
redvet68's Avatar
redvet68
Originally Posted by ED69ray
I just bought a fresh M-20 from a guy who specializes in rebuilding Muncie and B-W trannies.
His recommendation was 75/90 syn gear oil - I just filled it last week with Valvoline
good luck, Ed
I used syn 75/90 syn gear oil (Mobil 1 in my case, but I would not hesitate to use any good quality name brand in its place) in my M-20. Improved the shifting in my opinion and was the correct weight.
Old Jul 10, 2009 | 02:34 AM
  #39
Solid LT1's Avatar
Solid LT1
Originally Posted by Jeff_Keryk
Use GL-4. GL-5 is for differentials; it has additives that can damage yellow metals.
I agree Amsol has a GL-4 with "MT-1" rating meaning it is for gearboxes. There are many lubes out there that will not work well with our brass synchro tramsmissions. Adding 25% Lucas oil stabilizer works well too.
