1968 brake problem
Old Jun 27, 2009 | 01:09 PM
Vette-L79's Avatar
Vette-L79
Default 1968 brake problem
I am looking for help on solving a problem with the bleeding the brakes on my 1968. I am using a Motive power bleeder, calipers have been rebuilt with SS liner's and VPB piston with "O" rings, replaced the master cylinder, however with 10lbs. pressure the fluid just barely comes out of the bleeders. Any help would be greatly appreciated.
Old Jun 27, 2009 | 02:45 PM
...Roger...'s Avatar
...Roger...
Barely out of both front and rear calipers ? If so take the bleeder back off and away from the car and put it over a bucket and make sure its not the bleeder itself.
Old Jun 27, 2009 | 03:15 PM
Vette-L79's Avatar
Vette-L79
It is this way on all of the bleeder's. All of the bleeder's were cleaned last summer when I installed the new piston's. I also forgot to mention that the car has manual brakes.
Old Jun 27, 2009 | 03:38 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Pump that pressure pot up to about 15 or more.
DO a search here on the pressure bleeders, you'll see you need to clamp the reservoir top plate down
Old Jun 27, 2009 | 04:17 PM
Vette-L79's Avatar
Vette-L79
Thanks for the replies. I have the top plate clamped down now. I will try 15psi and post back results.
Old Jun 27, 2009 | 07:00 PM
Vette-L79's Avatar
Vette-L79
I just tried the 15psi with the same results as 10psi. Should I go to 20psi or higher?
Old Jun 28, 2009 | 12:12 AM
AzMotorhead
DId you pressure bleed the master cylinder?
Old Jun 28, 2009 | 12:58 AM
Clams Canino's Avatar
Clams Canino
Work backwards from caliper to master.
Remove the bleeder - better flow mow?
Could be the proportioning valve - rare but possible.
-W
Old Jun 28, 2009 | 08:08 AM
Vette-L79's Avatar
Vette-L79
No I didn't pressure bleed, however I bench bled the master cylinder.
Old Jun 28, 2009 | 08:12 AM
Vette-L79's Avatar
Vette-L79
-W
Is there anyway to check the proportioning valve? I suspect this is where the problem is. I will try removing the bleeder's one at a time.
Old Jun 28, 2009 | 12:06 PM
Clams Canino
I'm not sure of the proper method to test it. But I'd think that if you took one line off the output and steped on the break it outta pee fluid easily.
-W (68 roadster)
Old Jun 28, 2009 | 12:14 PM
'75's Avatar
'75
How old are your flexible hoses to the calipers? Those can look ok but be swelled almost closed on the inside. You could try removing the hose from one of the hard lines and see what flow you get.
Old Jun 28, 2009 | 12:16 PM
Mike Ward's Avatar
Mike Ward
'68s do not have a proportioning valve, it's a distribution manifold with an integral electrical switch to warn of pressure loss in either of the two circuits. Big difference!
Old Jun 28, 2009 | 12:30 PM
Vette-L79's Avatar
Vette-L79
I have no idea how old they are. I will try your suggestion on the front. I am having the same issue on all four wheel,s.
Old Jun 28, 2009 | 12:32 PM
...Roger...
If your using silicone fluid just crack one of the lines at the master cylinder to see if its coming through at that point then move to the next fitting towards the wheels.
Old Jun 28, 2009 | 12:41 PM
Vette-L79's Avatar
Vette-L79
I was reading about this in a Chilton's manual and it states that a brake warning light on the instrument panel should come on. Is this the same light as the emergency brake light, because that is the only brake light that I have?
Old Jun 28, 2009 | 12:59 PM
Clams Canino
Hi Mike!
I just went and checked my car and there's no way to be sure exactly "what" it is by looking at it.
It's there, and it has a wire attached to it for the light. Ecklers however, lists it as a "Proportioning Valve" at part number 48514. A different one is listed for 1969 (48515) and then 3 more for 70-73 , 74-77, and 78-82. They also have a chrome "replacement" for 74-82 at ony $79.
Are you sure it's not a true proportioning valve? Is the '69 one "real"? If not when did they get "real"? And lastly if you had a '68 would upgrading this critter to a real proportioning valve make a notable difference in brake performance. Do they all have the light switch built in?
-W
To 1968 brake problem
Old Jun 28, 2009 | 03:22 PM
Mike Ward's Avatar
Mike Ward
Yes, it shares the same light. It's easy enough to know if the light works, but difficult to know if the switch inside the valve works or not. I have heard of cases where the valve has been activated but that the switch is not working.
This may be contributing to your bleeding problems but check out all the normal culprits first.
Old Jun 28, 2009 | 03:26 PM
Mike Ward's Avatar
Mike Ward
-W
Only Corvettes with J56 brakes came with a proportioning valve prior to (I think) '78. Adding one to your car would not be an upgrade- much the opposite. The only proportioning action they perform is to reduce the pressure to the rear brakes.
Old Jun 28, 2009 | 03:31 PM
Clams Canino
Yes... I read the break sticky thread in the C3 tech forum and now feel I have a good education on what that foolish thingie does and does not do.
My LR caliper is currenty bad - so I can assure you that mine works, and the light comes on, and then the light goes back off... so I know that the pistons are at least trying to re-center.
I'll note that by the time you push the pedal down far enough for the idiot light to come on - you should already have gotten clues that something is wrong with the brakes.
