C3 Brakes
Old Jun 28, 2009 | 05:27 AM
patto's Avatar
patto
Default C3 Brakes
Firstly thanks to all involved for all the help with all my previous threads.
I bought an 80 vette thinking like the boats and sundry hobbies I previously had I would be over it within a year or so but unlike all before, the Vet still stirs the soul everytime I set eyes on it...... and driving it.....well.....for an avergae guy......it's nice to be envied for your choice of past time.
I have lots of clumbsy questions, I am a novice.
Here is another one.
I have had all the brakes overhauled from re sleeving the calipers to replacing pads and master cylinder and now booster.
The booster was done last and I actually had good pedal pressure with little travel. Over the past 4 months the pressure has settled and I now have long travel and a feeling the pedal is just about on the floor before I stop.
Is this normal for an 80 C3?
Old Jun 28, 2009 | 10:43 AM
Mike Ward's Avatar
Mike Ward
Try bleeding them, air in the system is a common problem.
Did you touch your rotors during the overhaul?
Old Jun 28, 2009 | 11:58 AM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
No, it's not normal. I agree about bleeding the system of any trapped air.
Old Jun 28, 2009 | 12:39 PM
larryg3's Avatar
larryg3
I agree sounds like you have air in the lines. are the brakes original? how about the hoses?
Old Jun 28, 2009 | 04:22 PM
patto's Avatar
patto
Yes the rotors were changed, the brakes are original and the hoses are most likely original.
Old Jun 28, 2009 | 05:05 PM
Mike Ward's Avatar
Mike Ward
Did you read up on the evils of changing rotors and inducing all sorts of problems (like low brake pedal) due to run out?
Ruh roh.
Old Jun 28, 2009 | 05:57 PM
Ganey's Avatar
Ganey
... and the hoses are most likely original.
Change all 4 hoses as when they get old they can collapse internally & not release the brake & bleed.
To C3 Brakes
