If you want to add brake fluid you need to know what is in there first. Silicone brake fluid does not mix with DOT3. If you change types of fluid you need to drain and flush the brake lines. The advantage of silicone is that it doesn't absorb water.
That being said i have used DOT3 for 30 years without ever having a problem. I just change the fluid every 2 years.
don't worry about what was in there! it is all gone
Keep it the same as your manual describes, unless your brake system has been thoroughly purged of all previous fluid and you put a tag on the top cover to your M/C calling out what fluid you have in it. Otherwise, some yo-yo at a repair shop or quick-lube place will do you an nice 'favor' and top off your M/C with the wrong fluid.
as i said before there is NO, zero, nada brake fluid in there!! if there is it is at the bottom rock hard. we will be blowing out the brake lines and replacing the rubber lines. so no worries about that.
"Blowing" through the brake lines will not purge them. You must completely flush the lines with a product that will eliminate the existing brake fluid completely. If you don't get it all out, you are risking contaminating the system and future problem. That's why I offered the "caution" to you. You asked...I provided my input. Use it or not.....
i will. bit the guy at the auto parts place said there was no such solvent or fluid that could get it all out. can you suggest anything??
we pulled of the bleeder valves off of the rear caliper and there was not any thing left...? can anyone explain? I didnt think that hydraulic fluid could evaporate?
