Windscreen slip
Old Jul 4, 2009 | 03:26 AM
patto's Avatar
patto
Default Windscreen slip
Just noticed my windscreen had slipped down about 5 mm on one side.
Looks like the rubber support on this side has worn.
Anyone advise how I might move this back up and re support, have tried to coax it back up but seems to have set this way.
1980 C3
Old Jul 4, 2009 | 03:48 AM
toolman1981's Avatar
toolman1981
1980 C3
Whats a "Windscreen"??????
By the way....Happy 4th.
Old Jul 4, 2009 | 03:57 AM
croaker's Avatar
croaker
It holds your inspection sticker on
Old Jul 4, 2009 | 06:24 AM
patto's Avatar
patto
Sorry what would you call it?
Old Jul 4, 2009 | 07:24 AM
79L48's Avatar
79L48
Your windscreen (we would call a windshield) needs to be pulled out, cleaned up and reset. It is likely "torqued" out of position and attempting to shimmy it back up will risk breaking it.
Old Jul 4, 2009 | 07:57 AM
patto's Avatar
patto
Sincere thanks 79L48 for the help and intuition, will take your advice.
And good luck to the toolman in this complex world.
Old Jul 4, 2009 | 08:33 AM
...Roger...'s Avatar
...Roger...
There is a good chance if you go to a glass shop and ask for it to be removed they will not guarantee not to break the windshield. It can be cut out carefully with thin wire or even some of the new braided fishing line.
I had a 69 tri power car in a few years back that had the same problem with a perfect windshield and the owner wanted it moved but not removed.
I siliconed a 3"x6" piece of sheet metal with lots of holes in it to each side of the windshield. I attached 3 braided wires to each piece of metal and brought them all to the top of the windshield to a turnbuckle type of contraption. I cranked up the tension on each wire and set the car out in the sun. It took about 3 days and the windshield moved back up. Naturally if your windscreen is not a keeper it wouldnt be worth this kind of effort. Good luck
Old Jul 4, 2009 | 04:58 PM
Alan 71's Avatar
Alan 71
Hi patto,
Since you used the term 'windscreen', I figure you're in England or Europe; maybe Australia. If so, congratulations on having a CORVETTE!!!
Regards,
Alan
Old Jul 4, 2009 | 05:04 PM
vettebuyer6369's Avatar
vettebuyer6369
Originally Posted by Alan 71
Hi patto,
Regards,
Alan
That and the fact he said it moved "5 mm."
Old Jul 4, 2009 | 07:09 PM
patto's Avatar
patto
Thanks Alan,
It's an Ozzie Vet an there is a strengthening following over here from the 'older timers'.
Old Jul 4, 2009 | 08:39 PM
vettebuyer6369
"Ozzie?"
Old Jul 4, 2009 | 09:57 PM
DZRick's Avatar
DZRick
Originally Posted by Vettebuyer5869
"Ozzie?"
Ozzie= Australian. I better add " I believe"
Old Jul 4, 2009 | 10:35 PM
...Roger...
Do you have the same windshields that we do or are yours tempered ?
Old Jul 5, 2009 | 05:09 AM
patto's Avatar
patto
I would say this is the original.
Tempered I think we call safety, that is if shattered if breaks into small fragments rather than shards, this looks like safety/tempered.
Old Jul 5, 2009 | 08:12 AM
...Roger...
Our side glasses are tempered and break into small fragments but our windshields are laminated and are 2 layers of glass with a thin film of plastic between them that are designed (I think) to contain and cushion the blow to passengers.
Old Jul 5, 2009 | 08:24 AM
Alex/plus's Avatar
Alex/plus
Hey Patto................
No matter if it's tempered or safety, you do not want to hit anything in these old cars !!
Send us some pic's of your car and beautiful country
Old Jul 5, 2009 | 08:45 AM
BB72's Avatar
BB72
[QUOTE=toolman1981;1570669315]Whats a "Windscreen"??????
It's the thing behind the bonnet.......mate
To Windscreen slip
