The cost would come to pretty much the same. The decision should depend on your use. If you are planning to drive the car a lot, I would put a crate motor in. If you are more of an original car guy, rebuild the motor.
Keep the old motor even if you are going to get a crate motor.
I have a GM crate motor in my 69. Not having any motor problems is a convenience.
I did a complete top-end rebuild and although the experience was nice and fun, if I had to do it all over again, I would of just bought a crate motor. You break even on cost, less time and effort. You get a warranty and all parts are new. And the original motor is intact.
What kind of hood do you have on the car? It doesn't look like that will fit under a stock hood
It does have an air gap intake, which required an adapter for my q-jet. So my stock hood did not fit. I went with an aftermarket l-88 hood.
I thought someone here fit a holley with a drop base air cleaner under a stock hood, but im not positive on that. But its still a good excuse to buy a new hood.
You could always sell that intake and buy a new one for not much price difference and avoid all the trouble.
Thanks for all the input. I think I will probably go with a crate, not sure yet. Problem is, I am doing the calipers right now and the more I look at the car, the more work I see to do. The front suspension is looking kinda old now too. And then there is the interior. Should really change the tranny out to a 5 speed too. Where does one stop?
It's an addiction. It's like the old commercial, Lays chips I think, "nobody can eat just one". With vette owners we can't just fix one think. One of the members went to change a fuse and ended with a frame off resto . Enjoy there is no cure.
Seriously, it never ends. And your just starting! I've had mine for about three years now and I've tripled what I paid for her already in projects and parts, etc. I've finally slowed down but I have so much more I want to do.
It never does end. I've done exactly the things you mention above and more. One thing you want to remember......keep all your receipts but NEVER add them up! I did and found out I could have had a real nice C5.......but look at all the fun I would have missed.
I'll just throw my 2 cents in here, as this subject has been beat to death many times in the past. First (maybe I missed it) but why does the engine need a rebuild? Without disassembly the cost / need for rebuild cannot, I repeat, cannot, be accurately assessed. If it only needs a hone and rings/bearings I say stay with what you got. If on the other hand the cylinders have a bunch of taper and need bore, pistons, etc. you may consider the crate route and wrap and bag your original engine in the corner. I have used Blue Print and highly recommend them as another poster said. They are very high quality for a reman company. The other problem with rebuilding what is in the car is finding a competent machine shop that will really provide accurate work nowdays. The cost will probably wind up about the same if you have to bore so these are the things I would consider. Good luck with what ever you decide.
You are answering an 11 year old thread, he's liable to have rebuilt it again since then.
Opps, my bad, I didn't look at the date!
I just figured out what happened, when I scrolled down I went past the end and wound up responding to "related threat"!
11 years is a long time but we wouldn’t threaten you.
