wierd tire problem???
Old Jul 9, 2009 | 08:00 PM
81shark2008's Avatar
81shark2008
Default wierd tire problem???
i am doing the brakes and calipers and it's on jackstands and we noticed that the driver side tire on the rear sticks out past the fender about an inch and a half but the other passenger tire is inside the fender wall. you can tell it's off visually like one side has a wide tire and one is normal but the tires are the same size and we looked underneath and see nothing wrong
Old Jul 9, 2009 | 08:21 PM
Roughrider's Avatar
Roughrider
The car could have been in a collision at some point and the repair wasn't done correctly. Most likely is the rear wheels may not match...one could have a different offset than the other or even two different width wheels.
Old Jul 10, 2009 | 12:48 AM
Steve COSD's Avatar
Steve COSD
When the car is on jackstands the wheels are pulled downward by the spring. It would be hard to determine alignment at this point. How are the wheels sitting when the car is sitting normally after driving?
Old Jul 10, 2009 | 01:56 PM
81shark2008
sits the same, it was sitting when i noticed it but is still the same jacked up
Old Jul 10, 2009 | 02:49 PM
pbcanney's Avatar
pbcanney
swap the wheels left to right side and see if your wheels are different offsets/widths
Old Jul 10, 2009 | 11:03 PM
7T1vette's Avatar
7T1vette
A most excellent idea...
To wierd tire problem???
