horn problem
Old Jul 11, 2009 | 07:14 AM
csl's Avatar
csl
Default horn problem
I have a '79 and none of the horns work. Where do I start? I understand there is a horn relay somplace and a horn contact in the steering wheel. How do you get the cap off the steering wheel to get at the horn contact? Does it just pry off or is there a special technique to remove it without breaking it?
Old Jul 11, 2009 | 07:34 AM
Duke94's Avatar
Duke94
Here's a link to the horn schematic for a 78' which should be close to your 79'. The horn button just pulls off.
Gary
http://www.corvetteforum.net/c3/tune.../index20.shtml
Old Jul 11, 2009 | 09:14 AM
speedreed8's Avatar
speedreed8
my 79 p.o. pulled the relay which hangs on a plug right above the fuse panel, because several parts were broken the in the steering column. he had also unplugged the connectors from the horns. i plugged in the horns bought a new relay, and she started blowing and wouldnt stop. i had to replace most of the horn components in the steering column. the horn button just pops off with a small screwdriver pushing just under the edge. good luck.
http://jimshea.corvettefaq.com/wp-co...sRev08AU04.doc
Old Jul 11, 2009 | 01:20 PM
csl's Avatar
csl
Thanks for the tip speedreed8.
To horn problem
