question on thermostats
Thanks for any thoughts........... Steve
what you want to do is take about 2-3 1/8 inch holes through the apron of the stat, that allows more water flow, and the engine can run cooler in a given ambient....
you can prove this really easy...remove the stat entirely and go for a drive....you have a cold engine even in 100f+ weather...ASSUMING of course you have a good operational fan and a decent cooling system....
Given the results of your testing and having no explanation for them, you did the right thing....go with what works!
I ran a jetboat with no Thermostat, it uses the lake water to cool with,
figured why run a stat? I had plenty of cooling so I ran without 1, the short story,
We completely fried the motor, the only explanation I, and the pro's could come up with, is without the thermostat, the water was moving so quickly thru the Engine, it did not have enough time to absorb the Heat from the Engine, ever since then I have ran Thermostats with no further problems.
Coincidence ? ...maybe ? maybe the same seniero with a high volume pump ? 69VETT
There is a lot more going on in there than just higher flow.
Without a tstat there might be high flow but less pressure. In a properly designed system, the pressure side of the cooling system might run as high as 40psi while the suction side runs at the rating of the radiator cap around 16#. Note the the rad cap is on the low pressure side.
Pressurized coolant has a very, very hard time cavitating and removes more heat because more coolant is in contact with the hottest sufaces and vapor is less likely to form.
When the tstat was put back in, then the increased pressure was again created in the engine and it cooled properly. Too much flow really isn't the problem, it's the reduced pressure. So the theory is also real world as it should be.
Same reasons a pressure cooker works better than an open pot.
I have the opposite problem, well maybe, if it's really a problem at all.
I run a stock brass rad, with a Shaw tstat (195°), stage 2 higher flow water pump, and barley gets to 185° with outside temps of over 95°.
Now I see a lot of posts that insist that all C3's will overheat if the coresupport foam and chin spoiler is not there. This car has neither the foam nor the spoiler and yes, the gauge has been verified with a pyrometer.
So obviously the high flow pump is not a problem.
BTW, smaller boat engines (with V8s) almost always come with 140° tstats.
I have a brand new 4-row radiator, a new sending unit, new water pump, new hoses and a 185 degree t-stat that does have a bleed hole. I did do the string test on the t-stat and it dropped off the string at 166 degrees and it was fully open at 189 degrees, (using a digital thermometer)
I have removed most of the air conditioning components except for the condencer in front of the radiator. All of the water passeges, (that I have been able to see)................. look clean with no rust. And water is still flowing through the heater coil. I also have temperature senitive lables on the t-stat housing and the inlet to the radiator. the lables are in 10 degree incerments.
The gauge and the lables indicate the same temperature, around 190/200, around town on a 85 /90 degree day. This is what I have been observing for a couple of months now.
On one of the hottest days here in SO CA I desided to go for broke and drove from Huntington Beach to Onatrio. Sustained speeds of 70/75 mph with lots of long gradual up-hill grades. Both gauge and lables indicate that the water temp. was running around 220degrees.
Ok, so I would at least like to get these temps. down a little........... hense my question about a high-flow t-stat.
Any more thoughts on this? And BTW, thanks for all the replies.
Steve
The "turbulence" idea is backwards. Turbulent flow through a pipe will increase heat transfer relative to laminar flow, so anyone using this argument to say that runninng without a t-stat is bad has their physics backwards.
The "cavitation" thing is just wrong. You don't get cavitation on the high pressure side of a pump, you get it on the suction side, so again, anyone using this as an explanation for a motor going bad with no t-stat needs to spend a little more time at the drawing board. When people are talking about "vapor" in the system, as opposed to cavitation, I am assuming that they mean that the coolant is boiling in the engine. While it is true that reducing the pressure in the system will make the boiling point lower, you would still have to get the coolant above its boiling point at the (lower) pressure of the system. If you are running a 50/50 water/ethylene glycol mixture, the boiling point at atmospheric pressure is somewhere around 230, so you would have to be well in excess of that temperature to get any boiling in your cooling loop. For all but the most dorked up systems, boiling coolant creating vapor space at the heat transfer area really isn't a concern.
I don't know why the fella with the burned up boat engine burned up his engine. There are lots of ways to ruin engines and I don't have nearly enough information to even take a wild guess which ones might or might not be to blame. While I accept it as fact that his engine got ruined at a time that he wasn't running a t-stat, we don't have any evidence at all of causality. In this case, where he was cooling with cold lake water, any "cavitation" arguments will be completely sensless unless the condtion of the water pump were so poor, that insufficient flow caused an overtemperature situation, a problem that would only be exacerbated by the addition of a t-stat.
Not enough restriction at the t-stat can cause more problems than it will solve.If you are running hot,have a good look at the rest of your system.
