carpet glue removal
Old Jul 21, 2009 | 10:10 AM
Sundevil64's Avatar
Sundevil64
Default carpet glue removal
What do you recommend that is reasonably priced and will not hurt the fiberglass?
Old Jul 21, 2009 | 10:27 AM
kayosnes's Avatar
kayosnes
I used a drill with a steel brush.
Old Jul 21, 2009 | 11:52 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Good idea. Lacquer thinner might dissolve the stuff, but you'd then be cleaning up a gooey mess.
Old Jul 21, 2009 | 12:23 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
a scraper and some elbow grease, that's a cheap, effective and clean way to do it, which is what I did to my car.
Old Jul 21, 2009 | 01:21 PM
MyRed69's Avatar
MyRed69
I used a drill with a wheel that was made out of some type of plastic fibers all glued together (something found in the bottom of my toolchest from who knows when) worked pretty well. Might be a little less harsh than steel on the fiberglass, depending on your 'touch' of course.
Old Jul 21, 2009 | 01:54 PM
7T1vette's Avatar
7T1vette
If the old adhesive is well adhered to the surface and does not have any significant thickness to it, just clean it up and leave it alone. It will be under the carpeting anyway. If you have a 'lump' of adhesive, scrape it down or use the wire brush method. Who's going to see it after you install the carpeting?
Old Jul 21, 2009 | 05:45 PM
WillEE's Avatar
WillEE
I agree - maybe an attempt to completely remove will be more time/money/energy/V.O.Cs than the outcome is really worth. Look at it this way - by leaving it alone your actually preserving the originality of your car.
Old Jul 24, 2009 | 04:55 AM
kayosnes's Avatar
kayosnes
I also are dempening / isulating the whole inside with dynomat extreme. And i wanted it all remove to be sure getting the best effect of the dynomat.
leaving tings alone is someting i wish i was better at. small tings always turn into big projects with me.
I lost a bolt from the wiper arm festing plate behind the dash.
That have now resulted in that the whole interior of the car is out. dynomat, changing the complete eletrical wiring, withe gauges and leeds in all bulbs behind dash. changed all vacum inside car, ac delete cover and new heater core +++
Old Jul 24, 2009 | 09:16 AM
Sundevil64's Avatar
Sundevil64
Good point. Thank you. I was kind of thinking this after a little thought.
To carpet glue removal
