helli coil
Old Jul 21, 2009 | 12:57 PM
rthawk1's Avatar
rthawk1
Default helli coil
I stripped a thread on my transmission. What are the pros/cons of a helli coil?
thanks in advance....rt
Old Jul 21, 2009 | 01:01 PM
waterplay's Avatar
waterplay
I have used helli coils several times and they worked great! Not sure of the cons!
Old Jul 21, 2009 | 01:33 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
The only con is that you'll have to drill out the hole a little and thread it for the helicoil. If the hole goes through to the interior of the transmission, the metal shards will too. Also a little challenging drilling and tapping with the transmission in place.
Those aside, no down side. A helicoil is a lot better than a bolt that doesn't hold anything.
Old Jul 21, 2009 | 01:50 PM
7T1vette's Avatar
7T1vette
If the damaged thread is on the tranny main case oil pan rail, I highly recommend you helicoil that one plus any others that look weak or have worn/damaged threads. I bought a helicoil kit with 16 helicoils, drill, tap, and installation tool. Then I did all the threads that passed completely through the pan rail and some others which had enough depth to assure not drilling into the body of the transmission. The bolts torqued up nice and firm with none of that "aluminum yield" feeling I used to get. And....no leaks so far.
The most difficulty I had was keeping the drill steady during the removal of the original threads. A hand drill will want to grab into the aluminum case and wobble around. If you have [or could rig up] some sort of a drill jig or drill bushing, the job would be easier; otherwise, just hold the drill as firm and still as you can while resting your hands on the underside of the tranny case.
Old Jul 21, 2009 | 02:13 PM
rthawk1's Avatar
rthawk1
thank you all very much......rt
Old Jul 21, 2009 | 04:35 PM
schmegeggie's Avatar
schmegeggie
Since it's in the transmission, you could try Loctite's Form-a-thread #28654. Good for up to Grade 5 bolts and up to 128 lbs. of torque. Must be clean! But should work for an "in place" repair.
Good Luck either way.
Old Jul 21, 2009 | 05:01 PM
7T1vette's Avatar
7T1vette
I'm not familiar with Form-a-thread. How does it work? Can you put more torque on the bolt than you were able to prior to use?
Old Jul 22, 2009 | 08:42 PM
Jim4924's Avatar
Jim4924
Default heli coil
keen serts are just as good if not better. In either one, make sure you pre drill the correct size or it will pull out when torqued.
good luck
Old Jul 22, 2009 | 08:44 PM
onaqwst's Avatar
onaqwst
i would also helicoil the hole where your speedo cable clip goes.... ask how i know...
To helli coil
