I've never had one, and since I eventually hope to actually drive the car some place - I'm going to need something. Any thoughts? Part of me says I won't be going far from home so it's not that important, but part of me says "be prepared" and "better safe than sorry"...
What will fit? Are there any newer-car donuts that I could use instead of a full-sized wheel/tire?
just buy a steel wheel and tire, that will be cheap, no trim ring or center cap. probably find a wheel on ebay for less then 50 bucks, and a new tire is ~80 bucks.
I dropped the hole spare tire assembly and put it into storage.
Hope new tires, can of tire inflato and AAA card works.
Don't drive on the shoulder of the road or over stuff in the road.
I found a used factory aluminum wheel and used Radial TA tire at a 24 hr. tire store. Cost $50.00. Check those in your area. I think tire size is 235/70-15. mds...
I removed the spare tire, put the spare tub (repainted it) back on and have been driving it this way for four years. I drive carefully and never run over anything. I also have AAA.
discounttire.com sells aftermarket rims in the stock size for 57 bucks shipped. add some rubber and for like 100 bucks have a good current production rim and tire
