Weatherstrip lubricant
Anyone have suggestions on what to apply to older weatherstripping to preserve it and keep it flexible? Any common household products or homemade items work?
I have used Die Electric grease too, as well as Armor All, and the tubes of silicone grease you buy at pool supply stores to lube and protect pool pump gaskets and O rings (kind of expensive too). All seemed to work just fine since I haven't had any weatherstrip deteriation problems.
I wasn't aware of the Delco product though. Is it liquid, or thicker like a gel or grease consistency?
I have used Nu-Vinyl for more than 25 years and swear by it. It is a polymer-based liquid (plastic....not petroleum-based) that is wiped on with a cloth and allowed to dry (a few minutes). It dries clear, no rubbing/no buffing, it seals the surface (plastic/rubber/leather), it won't peal or turn yellow, lasts 'forever'. You can add additional layers whenever you want and it blocks UV so that the surface below is not damaged by sunlight. It is particularly good for weatherstripping because it remains flexible but is non-sticky; so it doesn't 'grab' a metal/painted surface like the bare weatherstripping would. You can order the stuff from any ACE hardware store or over the internet (Amazon, etc.). I use it for my car's interior; vacuum, radiator, and heater hoses; plastic surfaces; and even the outer surface of my tires (makes them look like new rubber and keeps dirt from getting into the surface). You really should try it.
It's a paste. When I worked for a GM dealer it was used to accommodate customers who during winter decided to get a car wash to get road salt off their cars at -20/25*F. Needless to say their doors were frozen to the weatherstripping and could not be opened without damage to the rubber. In fact in some cases the doors could not be opened at all. This product repels moisture and leaves the rubber supple. And allows for the doors to be opened at those extreme temps. I use it on my vehicles. Prevents moisture penetration and subsequent rot. It's only about $5.00 and will do the whole car.
