Stripping Paint
Old Jul 22, 2009 | 08:18 AM
bfreema4's Avatar
bfreema4
Default Stripping Paint
I am to the point that i am ready to strip the paint off of my 77 vette. I have been told that a liquid striper is the way to go. Has anyone done this and how did it work. Thanks and I look forward to hearing your replys.
Old Jul 22, 2009 | 08:56 AM
Dream Ride's Avatar
Dream Ride
St. Jude Donor '09
I DA'd mine. But I've had years of practice with a DA. I shy away from liquid strippers unless everything is taken apart so there's chance of any getting left in the joints and messing the new primer and paint up. Using a DA can leave lots of waves if you're not used to how it works.
Old Jul 22, 2009 | 09:14 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I've used stripper. The trick to stripper is being patient and letting it work. Expect a gooey mess.
You will want a stripper which is fiberglass compatible. Cap'n Lee's, Auto Spray Strip, or something similar.
Old Jul 22, 2009 | 09:28 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
do a search in this forum many respones on this topic,
also look into stripping with razor blades,
everyone has their personel preferance for stripping.
69VETT
Old Jul 22, 2009 | 09:51 AM
halfmoontrail's Avatar
halfmoontrail
Especially for the original paint, I have found that razor blade stripping is an excellent method, and allows preservation of the high-quality factory primer layers.
It is surprisingly fast. I recommend the cheap plastic single blade razor holders, from CVS or other sources.
Steve
Old Jul 22, 2009 | 10:01 AM
jazz81's Avatar
jazz81
I agree with Easy Mike. I just finished doing my vette with Capt'Lee's. The most important thing is do small sections at a time, be patient and make sure you wash thourghly with clean soap and water when you are done, otherwise the stripper will continue to eat away at the car while you sleep. The key is patience. The first desire is to start trying to remove the paint as soon as you see it bubble. Wait and let the product do the work. The first panel I did, I tried to remove to quickly and made much more work for myself than necessary.
Good Luck
Mark
Old Jul 22, 2009 | 10:20 AM
timd02's Avatar
timd02
I did mine with a razor blade and heat gun. The heat is your friend but don't let it get too hot. Work a section at a time until you have it done and then move to another section. It won't take too long and you won't have the mess like you will have with chemical strippers. When you are done, you just sweep up the paint chips. I got a cheap heat gun from Oreily's for about $25. If you go with this method, just take it slow at first until you get used to how much pressure you need on the razor blade and the angle so that you won't gouge into the fiberglass.
Old Jul 22, 2009 | 11:17 AM
bfreema4's Avatar
bfreema4
Thanks all this really helps. Not sure which method i will go with they both sound good.
Old Jul 22, 2009 | 01:02 PM
rayluka's Avatar
rayluka
Worked good for me too
Old Jul 22, 2009 | 02:21 PM
TIE_Pilot's Avatar
TIE_Pilot
Stripping the paint is getting near the top of my TODO list too... the razor/heat method certainly sounds less scary than slathering chemicals all over the place... any estimates on how long it took though? It FEELS like it would be a big time commitment... free tims is the one thing I don't have enough of.
Old Jul 22, 2009 | 02:38 PM
blueray72's Avatar
blueray72
For those who stripped with a razor, what is the technique? Are you actually pushing under the layer of paint, or are you pulling the blade across the paint?
Old Jul 22, 2009 | 02:43 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
The razor method may or may not work depending on the primer and top-coats used. I tried on one of my 73's and I'm guessing in one of it's many resprays, somebody used an epoxy primer and the razor had no chance.
I went the acid route instead. Used something in a rattle can recommended my PPG paint shop. Worked fine. Be sure to put down large sheets of cardboard below your work. It is messy. You'll need a 1" painter's scraper, a half dozen sheets of red scotch-brite, and acid resistant gloves. After you've removed the paint, wash the car thoroughly with soap and water. It's recommended you not prime for a couple of weeks to let the acid leach from the fiberglass.
The good thing about fiberglass, it won't rust and you can wait as long as want to prime, unlike bare metal.
But good call, removing the paint. It will make the lines on your car look much more crisp after painting.
Good luck!
Old Jul 22, 2009 | 03:59 PM
bojangies46's Avatar
bojangies46
I use cap't Lee's I had 3 layers of paint on car but hood was not so bad.
Old Jul 22, 2009 | 04:49 PM
mr. creosote's Avatar
mr. creosote
I did some of the large, flat areas with razor blades initially. But, on most of the car I used Cap't Lees. I didn't like spraying it on. So I used a small brush to paint it on and a couple plactic bondo spreaders to scrape off the dissolved paint.
Old Jul 22, 2009 | 07:34 PM
Bow-Tie Guy's Avatar
Bow-Tie Guy
Well, I'm going through a chemical paint strip right now on my '81. I've only got the hood stripped at this point, but it really hasn't been too bad of a mess yet. I used Captain Lee's stripper and they included a spray bottle to use.
As others have said, patience is the key. I spray on a 2'x2' section at a time and wait 5-10 minutes for the chemical to work. After about 15 minutes, you can see the "crinkling" stop. That's when I use a plastic paint scraper to scrape off the "goop".
In all honesty, it's basically spray...wait...scrape...dump in trash. So far, the only time-consuming part has been the waiting. Good luck!
Old Jul 22, 2009 | 10:50 PM
KENS80V's Avatar
KENS80V
Cap't Lee's here too. It's a little bit easier with the body off. Don't get the chemical stripper on the urethane bumpers...it'll ruin them.
Old Jul 22, 2009 | 11:03 PM
hammadown's Avatar
hammadown
Do it enviormentaly and fiberglass SAFE...................
http://forums.corvetteforum.com/c3-g...ties-gray.html
Hammadown
To Stripping Paint
