Under the wiper area there is some dried out looking stuff, looks like lava if you ask me that area is the problem area normaly. the other is the t-top gasket it lets it leak inside(or at least seem like it) the bird cage.Normaly comes right down on the top of the left foot.right over the fuse area.Look at those locations first.
Get black ribbon caulk from NAPA/etc for about $16. Use between front window glass and stainless trim. Then in a dark area, like the garage, use a flashlight both inside and at the firewall to check for light coming through - then plug those leaks.
