Audio Question
Old Jul 30, 2009 | 10:38 AM
Tim81's Avatar
Tim81
Default Audio Question
I'm running a 600watt amp to two Subs and I have a question. Is it normal for the amp to get very warm almost hot to the touch? The sound is very good and there doesn't seem to be any problems with the amp at all, but it does get very warm.
Thanks Tim
Old Jul 30, 2009 | 11:16 AM
Stoge's Avatar
Stoge
Perfectly normal. If your amp has the "fin" looking things on it, they are called heatsinks, which are there to direct heat away from the amp's internals. They can get quite warm to the touch.
Old Jul 30, 2009 | 11:29 AM
Tim81's Avatar
Tim81
Thanks, Thats what I was hoping to hear....Tim
Old Jul 30, 2009 | 11:44 AM
929nitro's Avatar
929nitro
Old Jul 30, 2009 | 10:20 PM
spedaleden's Avatar
spedaleden
with above and your amp probably has a thermal shutdown. so if the amp does get too hot it will turn off and turn on again once it cools down a bit.
Keep rockin
Old Jul 30, 2009 | 10:53 PM
hammadown's Avatar
hammadown
Yes ......... your amp will get warm and then hot depending on how loud you play it. heat is the result of the amps inefficientcy to make QUALITY power to drive the subs. and when driving any subs you should be using a class D amp which are designed to drive only subs. even with a class D amp........ poorly designed amps will get HOT when pushed to the max and then they should trip the thermal breaker in the amp and shut it down till its cool enough to repower.
"Memphis" brand amps are high quality and the only amp I will use to drive my subs . and I play my music LOUD...........and my subs bang hard and my amp will hardly get above warm and I mean bang hard for 2or 3 hours straight. I have a Memphis 1100 W class D pushing 3 jl audio 10's.
Hammadown
Old Jul 31, 2009 | 08:51 AM
08vycpe's Avatar
08vycpe
Do these high power units require a higher output alternator? It seems like it would be a big strain on a standard alternator rated at 63 amps. Especially a car with A/C.
Old Jul 31, 2009 | 10:30 AM
7T1vette's Avatar
7T1vette
Yes.
Old Jul 31, 2009 | 11:40 AM
Dantana's Avatar
Dantana
Yes, I need to upgrade my alternator for example. When I run the stereo loud and the headlights, etc I can see that I am overtaxing the unit- although flickering headlights may look kind of cool at times, pretty sure it's not a good thing!
Old Jul 31, 2009 | 01:47 PM
onaqwst's Avatar
onaqwst
hookup a 4" computer fan to the blue wire(remote on) and use that to help cool the amp... the fans don't pull much amps (you could also relay it with the ingition wire or hott radio wire)
i run chrome ppi amps in my 77 6600 and 2600 2jl10w62 and 6/4/tweet component set
Old Jul 31, 2009 | 04:30 PM
7T1vette's Avatar
7T1vette
In my youth, I played bass guitar in a rock band. My amp would put out 100 watts RMS and would fill large ballrooms and outside arenas. I can't imagine why anyone would need {not want, mind you} 600 watts for an audio system inside a Corvette cockpit.... {My original Delco head has 16 watts, and I never turn it all the way up.}
Old Jul 31, 2009 | 05:01 PM
spedaleden's Avatar
spedaleden
I'm an old fart but it is nice to be young
Old Jul 31, 2009 | 05:22 PM
Tim81's Avatar
Tim81
The 600 watts is shared by my front speakers and two small subs, thats really not that much power for the number of loads (speakers) I'm using. I do not need the power for playing it loud, although the amp allows me to do that. The main reason for the amp is that the sound quality is much better, even at low volumes,then if I was just running from my head unit. There is a lot of good info here, thanks to everyone who shared their knowledge.....Tim
To Audio Question
