Radiator Replacement
Old Aug 1, 2009 | 08:12 PM
cam99's Avatar
cam99
Default Radiator Replacement
Need a rather inexpensive Radiator replacement, any one know where I can pick one up?
I've done a lot of searching, I need a 4 row, since that's what's in my 1977.
TIA
Old Aug 1, 2009 | 08:43 PM
Don Rickles's Avatar
Don Rickles
2017 C3 of Year
TIA
http://www.dewitts.com/
The way to go!!!
WB
Old Aug 1, 2009 | 08:49 PM
speedreed8's Avatar
speedreed8
inexpensive, yes, quality, hmmm (we'll see). i have one right now , its been good so far. lifetime warranty. the dewitts is the best though.
oriellyauto, proliance #433718 HD 4row, $260,
http://www.oriellyauto.com/EW3/Intro...33718&x=10&y=9
Old Aug 2, 2009 | 07:48 AM
82collectersvette's Avatar
82collectersvette
i still need to replace mine too, inexpensive as well.... ive been searching for a while and i found one for 190.00 for my 82, on this site http://www.radiatorswarehouse.com, so this is cheaper than anywhere else i looked, hope this helps
Old Aug 2, 2009 | 08:11 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
The way to go!!!
WB
I'm great at spending other people's money, but I just don't think there is alot of wisdom in trying to go on the cheap with a radiator. Go with a Dewitt's and be done with it. You will run cool and be glad you did.
Old Aug 2, 2009 | 10:59 AM
cam99's Avatar
cam99
What I'm afraid of is the lower outlet nozzle, it was already a bit tough to clear the Upper Control arm when removing it.
The radiator has to be almost exact OEM, I'm still using the original fan shroud.
Old Aug 2, 2009 | 11:14 AM
Jeff_Keryk's Avatar
Jeff_Keryk
Perhaps let your fingers do the walking. Call your local radiator shops and see what they can do. I am one to support my local shops, or one day they will be gone. Anyways, that's what I do.
Old Aug 2, 2009 | 11:34 AM
John Dingman's Avatar
John Dingman
What I'm afraid of is the lower outlet nozzle, it was already a bit tough to clear the Upper Control arm when removing it. The radiator has to be almost exact OEM, I'm still using the original fan shroud.
You are exactly right! The lower connector also runs REAL close to the stabilizer bar and if this tube angle is off just a little bit, the tube will hit the bar. Most of (if not all) of the copper replacement radiators are imported and many of them have fit issues.
I understand I we are not the least expensive replacement but we are also not the most expensive aluminum unit either. We will be at Corvettes@Carlisle in a couple weeks and you could save about $100 with show discount and shipping charges.
Rest assured, we know how to make them fit. The term Direct Fit is our trademarket. He is a pdf on our C3 units
http://www.dewitts.com/download/C3%20direct%20fit.pdf
Old Aug 2, 2009 | 12:34 PM
silver69's Avatar
silver69
I received my DeWitts last week, just waiting for the new seals to finish the job.
Great people to deal with, the radiator is beautiful and the shipping was really quick.
Old Aug 2, 2009 | 10:04 PM
DINO84's Avatar
DINO84
Can't you have a local shop recore it using the original tanks?
Old Aug 2, 2009 | 10:55 PM
Robert Anderson's Avatar
Robert Anderson
Go Dewitts!
Do it once, do it right.
I put one on my wife's 76 a few years back when we installed a GMPP crate motor.
Old Aug 4, 2009 | 08:19 PM
cam99's Avatar
cam99
I was going to go to Carlisle when I saw the savings but I have to drop my son at his first semester at College! that weekend
To Radiator Replacement
