? for you C3 Experts
Old Aug 3, 2009 | 04:40 PM
Stickboy97's Avatar
Stickboy97
Default ? for you C3 Experts
If you look at my profile I have an 08 C6, so I don't post much here in the C3 section.
I'm considering a project car next year and I'm down to a C3 vert (68-69) or a Firebird (68-69) and I'm trying to get a feel for a realistic build cost. I'm going to build more of a resto mod than an original.
Here's what I'm thinking and if anyone can help with their first hand knowledge or experience that would be great.
Looking to find a decent bodied car, so minimal body work, just a new paint job. I'll replace the engine with some kind of crate/stroker & I guess I'll need a new trany.... will I need a new rear end as well? Hopefully it'll have a decent interior, but I'll replace that if need be. Would like to upgrade the brakes to disc & add new wheels & tires.
I'm not looking to do a full out resto just more of a splash & dash upgrade so I can drive it & have fun.
What's a reasonable expectation for cost? Would I be better off looking for one thats already been updated? I don't really have anything that special in mind other than the paint color.
Old Aug 3, 2009 | 04:56 PM
Roughrider's Avatar
Roughrider
Personally, I think you'd be dollars ahead finding one already upgraded and then make whatever minor changes you wanted to personalize it. If you like the idea of a challenge and project for its own sake, have at it.
I would suggest looking for a '69 as the '68s had a number of one year specific parts that are somewhat more expensive to find. If you find a '68 at a great price, go for it.
C3's are great cars, but keep this in mind..."There are few things more expensive than a cheap Corvette"!
I'm not very familiar with Firebirds of that era so I can't say which would be less expensive. I can tell you that nearly every part you would need for an early C3 is available...not all, but most are available as new or reproductions and there are many vendors specializing in it. I don't know if many other cars can say that to the same degree as a Corvette.
Old Aug 3, 2009 | 05:14 PM
crvtownr's Avatar
crvtownr
I would say:
Engine 3500-5000
Paint 3500-5000
New Tranny 1500-2500+ depending on how much hp its behind
Brakes upgrade (not sure what you want) 500-1000
Wheels/tires 1000-1500
You didn't mention suspension, that's another expense. This is considering there are no frame/birdcage issues.
JMHO
Old Aug 3, 2009 | 07:56 PM
whitehause's Avatar
whitehause
Sounds like a rolling chassis would be the way to go. Like was posted before, go 69 or 70 for parts availability and lower cost. I have 2 68's and some of the parts are much more expensive.( 200.00 more for the weatherstrip as an example) Vetts had disc brakes all the way around anyway, but stainless lined calipers are almost a required upgrade, and may have already been done at some point. The rears in vetts were very good to begin with, so a new rear probably would not be needed....maybe a mono-spring and good shocks for improved ride. I think the vette would be the way to go(obviously) they tend to be a bit "classier" .The old birds were very cool but still say teenager to me when I see one drive by(showing my age I guess)
Old Aug 3, 2009 | 09:50 PM
axelz's Avatar
axelz
To restore or rebuild a 1969 C3 give you a pain in the wallet. It's better to find one that just about what you are looking for, then you can go from their $$$$$$$$$$$$ Some years are more expensive than other for parts and value. A C3 is a good looking car.
Old Aug 3, 2009 | 11:44 PM
Stickboy97's Avatar
Stickboy97
Thanks for the info! Obviously I lean heavily toward the vette too. I figured somewhere in the range of $20k to make it how I want it(+ the car itself), so I'm not far off. I know with vettes or any car for that matter the sky can be the limit, but I'm looking for a good quality strong driver that can scream as well. I'd love an all original 427 1969, but so does everyone else.... hence their prices these days. I was hoping for somewhere in the neighborhood of $30-$35k I could build both a beauty & a beast.
Again, thanks for the info and I'll be around this side of the forum more as the day gets closer to me starting my project. I'm sure I'll choose the vette.
Old Aug 4, 2009 | 08:50 AM
Ganey's Avatar
Ganey
I had a 69 Firebird 400 conv. & a Trans Am before the Corvette. They are cool cars but they are not Vettes.
An issue w/ the Firebirds is rust.
To me the Corvette is the way to go!
Look at some other years also.
Old Aug 4, 2009 | 10:28 AM
7T1vette's Avatar
7T1vette
Your best buy for a C3 would be a '72 or '73 SB coupe. In today's market, you should be able to pick one up with a good body...but worn/damaged paint...for around $10K. But, with a new paint job, engine and overdrive tranny, it will clean up nice and the car's value will be somewhere near $20K.
Old Aug 5, 2009 | 08:24 PM
Stickboy97's Avatar
Stickboy97
Though I love all vettes, I really want to redo a 69 vert. If I have to spend a little more to get what I want it'll be worth it!
Old Aug 5, 2009 | 08:43 PM
72LS1Vette's Avatar
72LS1Vette
If you are looking for a 68/69 to resto-mod try to find one that doesn't have the original motor. Non-original cars of that vintage are worth considerably less to collectors so you can find one for a much more reasonable price. If you want to go crazy and put a SRIII tube frame under it with C4 suspension you won't feel guilty about it.
Rick B.
Old Aug 5, 2009 | 09:41 PM
SuprJames's Avatar
SuprJames
Buy one already done or close to being done. Otherwise you'll be $40K into it without even blinking an eye. Pay for a nice one up front or a project that is not quite finished.
Old Aug 5, 2009 | 10:13 PM
427-390's Avatar
427-390
Stickboy97,
For less then 30 - 35K, you should be able to pick up a decent driver quality small block car and just replace that engine with a built small block, build up the motor that comes with the car, or drive it as is. A decent driver quality 69 'vert shouldn't be more the 25K, add the motor for another 5K and you're good to go. Be patient and wait for the "right" car. Stop in and ask questions, and more questions, and more questions. Like others have stated, buy the most car for the money to start with. You don't want to buy a car that turns into a money pit. Good luck with your search.
Old Aug 6, 2009 | 05:37 AM
Purple Corvette Jim's Avatar
Purple Corvette Jim
Default Change to stick from Auto for 1979 ???
I have a line on a 79 Black on Black automatic. Want to make the change to a 4 or 5 speed. Will need ALL the change parts. Are they available from vendors?? Of course buying one with stick would be the way to go, but not many are stick cars. So will have to go the change route. Imput would be appreciated.
Old Aug 6, 2009 | 09:06 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Purple Corvette Jim
...Imput would be appreciated....
Keep looking until you find a 4 speed car. The swap from AT to manual is expensive.
Old Aug 6, 2009 | 11:09 AM
70 LS1's Avatar
70 LS1
Sent you a PM.
Old Aug 6, 2009 | 11:18 AM
70 LS1's Avatar
70 LS1
I think your estimate of 20K plus the cost of the car is pretty good for a nice cruiser.
It would be cheaper to find one already done, but if this is to be a "project" then half the fun is building it yourself. If you do buy one partially done, hold out for one that has most of what you want. If I had a 35K budget, I would buy a nice car in the 20-25K range and use the rest to make it perfect.
All C3's have disc brakes. You can upgrade those if you want, but a properly operating stock C3 setup is pretty good.
Old Aug 6, 2009 | 10:37 PM
Stickboy97's Avatar
Stickboy97
Again thanks for all the info.
If I buy say a cruiser with a non matching engine (don't care which since I'm going to pull it, I guess a 350 will be least expensive) can I just swap out the engine and leave the tranny (stick) that came in the car? Won't I need to swap that for the extra power (and torque) the new engine will have? What about the rear end? If they already have disc breaks are they of good quality? Do they even need to be updated?
From what some of you are saying I might be able to pick a decent driver car, swap the engine, maybe paint it & fix up the interior some and be done... true????
I've watched 69 prices for quite some time (6-7 months) and noticed something thats hard to find.... power windows in a vert. Why???
thanks
Old Aug 7, 2009 | 12:09 AM
70 LS1's Avatar
70 LS1
thanks
You can leave the 4-speed, but you might want overdrive at some point. Makes for a nice cruiser and allows more rear end gear for that off the line punch.
The rear end in the early C3's can withstand quite a bit. I seem to recall 550 or 600 or something like that.
The stock C3 brakes are actually quite good. Four wheel four piston calipers and 11.75 rotors were ahead of their time in the late 60's. They do suffer from fade after repeated hard stops and they are quite heavy. You can upgrade to Wilwoods to cut out some fade and weight.
C5/6 upgrades are available, but offer minimal gains over stock.
To ? for you C3 Experts
