Need Advice Frame Finishing
Old Aug 5, 2009 | 09:38 PM
dprinter1's Avatar
dprinter1
Default Need Advice Frame Finishing
I'm looking for your input/advice on powder coating VS painting the frame and suspension. There are no visible holes in my frame, but there is alott of rust on the inside, how is this best dealt with. I found large mice nests in the frame and duct work, I can imagine that they crawled all through the car and did their thing, it smells like rat pee...BAD. It sat in a pole-barn for many years.
Your advice on blasting and finishing will be appreciated
Thanks in advance,
Dean.
Old Aug 5, 2009 | 09:44 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
POR 15, and they now make these really nice brush/swabs on very long wire handles,
specifically to reach inside of frames, cheapest, easiest
and probable best other than a chemical dip.
Power wash inside and out, and start painting,
POR15 leaves a perfect finish no brush marks.
Wear protect gear ! POR15 will not come off of you !
well maybe after about 2 weeks !
69VETT
Old Aug 5, 2009 | 10:47 PM
dprinter1's Avatar
dprinter1
POR15 leaves a perfect finsh no brush marks.
69VETT
I think its just about imposible to get all of the insid frame down to bare metal, aside from chemical dip. So if I use this product will it stop the rust or just cover it up?
Thanks,
Dean
Old Aug 5, 2009 | 10:54 PM
69Vett's Avatar
69Vett
Both ! check out the product, I have used it on many things, it literaly stops Rust,
and with enough coats can completely cover any sign or pre-existing rust.
They actually recommend not removing all rust before application.
Best thing since sliced bread !
Old Aug 6, 2009 | 12:29 AM
joewill's Avatar
joewill
POR15 does come off with laquer thinner.. if you don't let it cure/dry on your hands overnight
Old Aug 6, 2009 | 05:02 PM
Alan 71's Avatar
Alan 71
Hi DS,
I had my frame powder coated after I stripped it. When I got it home I felt as though it was a little too glossy for the look I wanted. I scuffed the entire frame with 400 and sprayed it with Krylon #1613. It's holding up very well and I was able to do the little touch up I needed as I reassembled the car.
Regards,
Alan
Old Aug 6, 2009 | 06:26 PM
1982CorvetteDude's Avatar
1982CorvetteDude
Jason Bourne says por-15 works great
J/K That's what I'm going to use when I do my frame....
Old Aug 6, 2009 | 07:19 PM
SuprJames's Avatar
SuprJames
My only gripe with powder coating is that as soon as it gets a chip and rust takes hold it will start to lift.
Another vote for POR15 (which also isn't perfect, but I think is a better option)
Old Aug 6, 2009 | 09:03 PM
3JsVette's Avatar
3JsVette
If properly applied POR15 is a water tight coating that stops rust from advancing.
Old Aug 6, 2009 | 09:19 PM
72LS1Vette's Avatar
72LS1Vette
I like RustBullet www.rustbullet.com
Less prep work than POR, it sticks equally well to rusted and clean metal and can be topcoated with any kind of paint.
Rick B.
Old Aug 6, 2009 | 09:52 PM
blueray72's Avatar
blueray72
I remember someone using a bug sprayer to spray inside the frame
I PC'd my frame but there was very little rust. I did POR some pieces, stuff works great.
Old Aug 6, 2009 | 11:04 PM
dprinter1's Avatar
dprinter1
So you guys got me re-thinking my plan.
blueray...the bug sprayer sounds like a good idea for the inside, I'm think some sort of flexible tubing with an atomizer on the end hooked up to the compressor, yes, I'm having a vision
I don't have any experience with any of the places around here that does blasting so I'm wondering what blasting media I should tell them to use?
Also, if anyone in the Nofolk VA area can recomend a place to get the blasting done that would be very helpfull.
Thanks blueray, and everyone else that has posted to this thread
Dean
To Need Advice Frame Finishing
