Which to do first? Paint or Interior
Old Aug 17, 2009 | 06:25 PM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
Default Which to do first? Paint or Interior
Currently my car is primed and somewhat blocked out. I will need to prime and block at least once more on the day of painting.
Meanwhile, the doors and hood are off and the interior is completely removed.
Unfortunately I wanted to get the car mobile again so I elected to finish the motor and put it in recently. While the motor was out I replaced just about everything i could think of in the suspension, steering, and brakes.
So, my question is: should I do the interior first or the paint? Does it make any difference?
Old Aug 17, 2009 | 06:43 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
paint first, .... nothing like overspray on that new interior.
and the painter saying, opps ! sorry ! 69VETT
Old Aug 17, 2009 | 08:01 PM
BigBlockTank's Avatar
BigBlockTank
Paint first, always.
Robb, who's painting your car?
Old Aug 17, 2009 | 08:04 PM
GREGG-73's Avatar
GREGG-73
Paint.....next question....
Old Aug 17, 2009 | 08:08 PM
3JsVette's Avatar
3JsVette
Another for paint 1st. Look at all the high end hot rod and pro-touring builds on line you won't see an interior in a car before it's painted
Old Aug 17, 2009 | 08:26 PM
longbros's Avatar
longbros
Interior first. No sense in scratching up the new paint while you are lifting those seats, etc. in and out of the car.
Old Aug 17, 2009 | 08:56 PM
RobbSalzmann
St. Jude Donor '12
Hiya BBT,
I'm thinking me. You have an suggestions?
Old Aug 17, 2009 | 08:58 PM
RobbSalzmann
St. Jude Donor '12
Thanks everyone for chiming in! It probably seems like common sense but I wanted to see what people have to say about it.
Old Aug 17, 2009 | 09:00 PM
CCrane65's Avatar
CCrane65
Paint first unless you like spending a ton of time and energy cleaning dust out of your new carpet, your vents and every other nook and cranny in the passenger compartment.
By the way, body shops apparently assume you are replacing the carpet because they take off all the trim and let water from wet sanding run through the holes like the ones on a convertible deck lid.
cc
Old Aug 17, 2009 | 09:03 PM
ksbunting's Avatar
ksbunting
Paint first
I had to make the same decision when I did my 68 resto.
The body shop gets overspary and dust everywhere nomatter how good you mask.
Interior last, much easier that way
Kurt
Old Aug 17, 2009 | 09:08 PM
MakoShark72's Avatar
MakoShark72
Absolutely....Paint first.
BigBlockTank
Originally Posted by RobbSalzmann
Hiya BBT,
Well, I started in the USAF in 75 as an aircraft painter, but..................................... ..................................
my plate is full right now. I'm doing a 69 Mach I for a friend, a 54 Jeep paint job soon, and I'm trying to do some more on my 69.
Did you get a message from me about the tour of AMARG? That's the Boneyard. We're doing a tour on another forum on 25 Sep. @ 10:00 AM. Let me know if you want to join in.
Tank
Old Aug 17, 2009 | 09:14 PM
SteveG75's Avatar
SteveG75
Paint first. I took my entire interior out before my car was painted. Reinstalled it after. You can always protect the paint if you are worried about scratching it when installing seats, etc.
Old Aug 17, 2009 | 10:02 PM
markdtn's Avatar
markdtn
Paint first.
Old Aug 17, 2009 | 10:47 PM
7T1vette's Avatar
7T1vette
No question....paint first.
Old Aug 17, 2009 | 11:09 PM
temvette72's Avatar
temvette72
As a former upholsterer, I say please paint first. We never screwed a paint job in our shop, but had to fix lots of overspray on new interiors! Use a good shop (or do it yourself!) and you won't regret it!
Temvette72
Old Aug 18, 2009 | 01:01 AM
mapman's Avatar
mapman
Paint First.
Note: On the St Louis line, the interior WAS NOT installed until it PASSED a water leak test.
When the car was originally built, they dropped the painted body onto the frame/engine, then they performed a WATER LEAK TEST, THEN they installed the interior.
You might consider checking for water leaks BEFORE you install the interior.
To Which to do first? Paint or Interior
Old Aug 18, 2009 | 06:47 AM
jimo's Avatar
jimo
Old Aug 18, 2009 | 11:38 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
FWIW: On the assembly line, bare bodies were completely painted before the interior was installed. There's a reason for that.
Paint first.
Old Aug 18, 2009 | 12:35 PM
929nitro's Avatar
929nitro
Paint first.
