'71 steering column rebuild
Old Aug 18, 2009 | 04:18 PM
lwp's Avatar
lwp
2nd Gear
Default '71 steering column rebuild
Hi all,,
new to this, but I'm in the middle of a resto for a '71 and I'm looking for any help I can get on two things:
a. tilt/tele sterring column rebuild kit, instructions, guide - whatever, I just need to rebuild this thing.
b. question: I've replaced the interlock cable with a new one as the old one was kinked, and the key wouldn't come out. Now, 2 months later, the same thing happened, the new cable is kinked in the same spot. what's up? I'd hate to get a new one and have it happen again.
any help is greatly appreciated.
Old Aug 18, 2009 | 04:41 PM
Alan 71's Avatar
Alan 71
Hi lwp,
Jim Shea is THE steering column MAN! Search for his threads.
Where is the kink occuring? That might give someone a clue as to why.
Regards,
Alan
Old Aug 18, 2009 | 07:28 PM
Duke94's Avatar
Duke94
Here's the link to all of Jims Tech papers. Add it to you "favorites" list.
Gary
http://wiki.corvettefaq.com/index.php?title=Main_Page
Old Aug 18, 2009 | 07:40 PM
Frogday's Avatar
Frogday
If you are getting another column lock cable, get the reproduction instead of the service replacement. The reproduction will be less likely to kink, it has a metal sheath with a wire wrapped around. Make sure you have both brackets on the transmission, they should help prevent the kinking.
To '71 steering column rebuild
