my estimates for a 72 resto.
Old Aug 19, 2009 | 02:54 PM
crf311's Avatar
crf311
Default my estimates for a 72 resto.
I can't decide if I want to rebuild a 72 BBC with 454BBC, AT, AC, PB, PS, or a 69 camaro needing a lot of metal work. I started writing up my budgets on both, and this is what I came up with for the vette:
Blast n Paint Frame 500.00
R N R rear end diff and trailing arms 1300.00
New SS fuel N brake lines 250.00
R N R Brakes 600.00
R N R Front end 300.00
R N R power steering 300.00
All new wiring 1100.00
new interior 1350.00
New dash 925.00
Fuel tank 175.00
AC Rebuild 1000.00
Paint 1500.00
extra's 1500.00
How's my # look to you. I will be doing all the work myself. I already have a motor and transmission, although I my change the trans to a overdrive unit.
Old Aug 19, 2009 | 03:59 PM
63Nova's Avatar
63Nova
Are you doing this yourself?
If you are I would say your front end costs are a little low, the wiring is extremely high, power steering may be low, rear diff and trailing arms may be high, paint is low, a/c rebuild is high, interior is low.
Old Aug 19, 2009 | 04:19 PM
eastltd's Avatar
eastltd
Your numbers look a little low if you are replacing all with new components.
Grab a Zip or Ecklers book and price out your components then add for shipping, fasteners, paint, shop supplies, tools, etc....
I kept a spreadsheet of costs during my rebuild. Send me an email address and I'll pass it along to you.
Old Aug 19, 2009 | 04:24 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I've always heard a Corvette restoration will require three times the cost you think it will and five times the time.
Old Aug 19, 2009 | 04:57 PM
crf311's Avatar
crf311
Thanks for the input guys. Most of the prices are from pricing a had from my 69 resto that I finished last year. Most parts will be remove and rebuild. The paint price is for the paint only since I will be doing the prep and spraying again. Really I can't decide if I want to do another vette right now, or change it up and do the camaro. Both are going to get done it's just a matter of which goes first.
Old Aug 19, 2009 | 05:00 PM
MCMLXI's Avatar
MCMLXI
Finalist 2022 C1 of the Year - Unmodified
2020 C1 of the Year Finalist - Unmodified
C1 of Year Finalist (stock) 2019
Old Aug 19, 2009 | 05:19 PM
Alan 71's Avatar
Alan 71
Hi crf,
2 things I didn't see were chrome plating and tires.
I think your list is short and very light on 'extras'. For example what if the tach, radio, clock, and wiper motor/pump need to be rebuilt?
Since you just did a Corvette I'd lean toward the steel car.
Regards,
Alan
PS: It really depends on what YOUR definition of 'restoration' is, too!
Old Aug 19, 2009 | 06:53 PM
crf311's Avatar
crf311
Originally Posted by Alan 71
Hi crf,
Regards,
Alan
Alan
Thanks, I did forget about rechrome on the bumbers.
Thats another 600.00.
My restoration definition is pretty much touching every nut and bolt on the car, but not a NCRS restoration, thats just not my thing.
Old Aug 19, 2009 | 09:16 PM
3JsVette's Avatar
3JsVette
Yeah me too! While these numbers may be a slight exageration any restoration will cost more than you budget for and take a lot more time than you thought. There are plenty of surprises with any "complete" rebuild.
Old Aug 19, 2009 | 09:18 PM
jfleye's Avatar
jfleye
Default rebuild
Ive spent just over 25k on my 71 and did all the work myself.
Paint and primer--1800.00 material only
Old Aug 19, 2009 | 09:47 PM
joewill's Avatar
joewill
exhaust, chrome, cooling, hoses, lines, tires. .perhaps triple the 'extra's estimate
Old Aug 19, 2009 | 10:01 PM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
I noticed a few unders and overs myself but then again I'm not doing the work and didn't know what CRF's def of restore was. I will say that as I do the same to my 69, the rough estimate was exceeded long ago. Now I just keep the pad of sticky notes on the workbench because as I continue the teardown, there's more parts to go on the order list.
Old Aug 19, 2009 | 10:28 PM
markids77's Avatar
markids77
I have about $500 just in bushings, special tools, seals paint and fluids in my rear suspension alone... I haven't done any brakes, u-joints, wheel bearings or even wheel studs ( a MUST have!!!!) yet. I do include a set of 4 GR-@ shocks in the total... but I did all the labor! I expect a ready to ride rear running gear renovation... NOT resto will cost $1.5K including alignment, and fresh rubber on restored factory wheels. Add $400-600 for rebuilt hubs.... your cost might vary. Triple your estimate and add 30 percent... might be closer.
Old Aug 20, 2009 | 09:33 AM
CCrane65's Avatar
CCrane65
You should add about $3000 for unique '72 BB with A/C only parts like carburetor, fan blade, overflow tank bracket etc. Many of those parts were discarded in favor of off the shelf parts long ago.
cc
Old Aug 20, 2009 | 09:37 AM
vettebuyer6369's Avatar
vettebuyer6369
Originally Posted by crf311
extra's 1500.00
This one jumps off the page as a little light.
Think 3 times your total when its said & done.
Old Aug 20, 2009 | 10:38 AM
crf311's Avatar
crf311
A couple more items I forgot:
Weatherstripping 300.00
Shocks 200.00
Old Aug 20, 2009 | 12:04 PM
jaki30's Avatar
jaki30
When you say front end/brakes are you counting on replacing the brake backing plates, wheel bearings and grease seals? How about brake lines and gas lines? How is the radiator and core support? Any frame work needed? Do you have all the A.I.R. equipment? That alone will cost a couple grand.
I spent over $8,000 in 1988 on my 72 LT-1 air coupe restoration. My original estimate was $2500 - 3000. Wrongo! Good luck.
Old Aug 20, 2009 | 03:48 PM
avner's Avatar
avner
Poor restoration - $10,000-$15,000
good restoration - $15,000-$25,000
Excelent restoration - $25,000 & up north.
and if you doing by yourself, only good paint $7,000 -$12,000
Avner
To my estimates for a 72 resto.
