Question running stereo wires
Old Aug 20, 2009 | 01:37 PM
turbojet's Avatar
turbojet
Default Question running stereo wires
1971 coupe where did you run the wires from the amp (in the rear) to the front speakers and radio. Every thing is out so down the middle or under the seats down the side. What would be the cleanest way.
Old Aug 20, 2009 | 03:02 PM
spedaleden's Avatar
spedaleden
Since everything is out. I would run all speaker wire and low level RCA's through the center console. Depending if your using amplifiers, power to the battery and keep your grounds together and mount ground as close to amps as possible.
Old Aug 20, 2009 | 03:35 PM
turbojet's Avatar
turbojet
Old Aug 20, 2009 | 05:40 PM
BigBlockTank's Avatar
BigBlockTank
I think what he means, is, keep the power and ground away from all the speaker wires and RCA cables. It causes problems that you don't want.
I did mine not too long ago, and I don't have any problems.
Old Aug 20, 2009 | 05:43 PM
onaqwst's Avatar
onaqwst
keep the ground/power wires away from teh speaker wires...sometimes you can pickup a 'buzz/hmmmm'.... also make sure you have good grounds and inline fuses to the amp... don't use crappy rca's either... spend the money and get good rcas
Old Aug 20, 2009 | 05:55 PM
turbojet's Avatar
turbojet
took the car apart today will be putting the system in tomorrow will take pics.
Old Aug 20, 2009 | 06:10 PM
CCrane65's Avatar
CCrane65
I ran mine through the courtesy light access, under the carpet, over the wheel well, behind the quarter trim panel, along the curve where the floor meets the door sill. Basically I followed the path the antenna cable takes on both sides.
Amp is mounted on a 14" by 15" board with power and ground cables running under the carpet to the battery box under the storage compartment frame.
Low profile sub box with 10" Kenwood sits next to the board above and takes up remaining floor space (about 15") to the other wheel well.
And I still have room to store my back window.
cc
Old Aug 21, 2009 | 11:04 AM
john roth's Avatar
john roth
Search This Forum - Simple Stereo
Old Aug 22, 2009 | 03:06 PM
turbojet's Avatar
turbojet
Some progress got the amp mounted where I wanted it the sub is almost finished needs to be covered with some fabric. Ordered new
speaker mounts for the dash since I didn't want to cut the originals. I will post pics of that when I do it. Here are some pics.
To Question running stereo wires
