Trying to remove body
Old Aug 21, 2009 | 03:01 PM
Cuervos77's Avatar
Cuervos77
Default Trying to remove body
Okay im swapping a new engine into my vett a 454 so i wanna take off the body also am panting the body easier to paint i hear but i couldnt find anything in forums about removing the body how much is it what exactly do i have to take off what do i leave on anyone done this already ???
Old Aug 21, 2009 | 05:14 PM
Alan 71's Avatar
Alan 71
Hi C77,
Getting ready for, and lifting the body, is a TREMENDOUS amount of work.
I suggest you start by searching the C3 Tech/Perf Forum for 'bodyoff' and 'frameoff'. LOT'S of threads and information!
Regards,
Alan
Old Aug 21, 2009 | 06:52 PM
Duke94's Avatar
Duke94
This thread has lots of info on removing the mounts. Do a search on "body lift" and you should find lots of info and pics on lifting the body. Good luck,
Gary
http://forums.corvetteforum.com/c3-t...-bushings.html
Here's one showing a lift.
http://forums.corvetteforum.com/c3-g...ting-rack.html
Old Aug 21, 2009 | 07:48 PM
wer2xu's Avatar
wer2xu
Do you have a copy of the AIM?
Old Aug 22, 2009 | 10:25 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
My advice is not to remove the body if you don't have to. You can leave her in one piece and swap an engine or repaint.
There are several Corvette restoration books on the market. Most of them deal with C2s, but the process is essentially the same. Noland Adams has a series of books and videos, plus a How-To checklist. Purchase three or four of these, read through them to see how others have done it and to get an idea of what you're up against, then decide what you want to do.
Old Aug 22, 2009 | 10:56 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
If your swapping in a BB in place of a SB you have a ton of work to do,
and that does not include or require taking the body off.
I suggest you think thru your plan of what you wish to do with the car'
and how much resources, time and Money you plan for this project.
Body off is a whole new (time consuming Project)
It really is not any easier to paint the body off,
and many say actually better to paint with Corvette body on,
to get the correct gaps for doors and such.
I just finished a body off, and ended up with body back on the frame for paint. 69VETT
Old Aug 22, 2009 | 02:34 PM
Cuervos77's Avatar
Cuervos77
exactly how much work is getting the 454 in i heard it was a easy drop well not easy but simple enough does it fit inside what ton of work am i looking at plus ive been doing most of the work myself so i like a good challenge
Old Aug 22, 2009 | 05:24 PM
69Vett's Avatar
69Vett
you must have all " Corvette BB " brackets and pulleys,
you will need hood clearance, bigger radiator and larger radiator core support.
radiator Fan new Exhaust, everything has about 1/4" clearance or less. 69VETTE
Old Aug 23, 2009 | 11:00 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by Cuervos77
...i like a good challenge...
The challenge is knowing what you're in for before you jump into it. Purchase the AIM for any year the big block was available and take a look at the factory installation. The AIM will list all the orginal part numbers you're going to need and show diagrams of how the installation was done on the assembly line.
Old Aug 28, 2009 | 12:03 AM
snmnjones's Avatar
snmnjones
Default C3 body off restoration
I am in the middle of a body off restoration on my C3. Getting the body off was not as difficult as I thought. Going back on may be a different story. I did a chemical dip and powder coating of my frame. The frame was in good condition but there were areas that I was not certain of its condition with the body on. At first I was going to paint the body off of the frame but I have decided on painting once I put it back on.
Another area that I could not assess was the condition of the brake lines. They turned out to be fine but I am replacing them with stainless. I was nervous about the brake lines as my lines on my 97 Dodge failed but I guess they don't make them like they used to.
A couple of things that are in my favor is I am retired and I have a couple of car lifts. I would hate trying to do the body removal without the lift.
To Trying to remove body
