What Makes a '68 "Special"
Old Aug 23, 2009 | 04:58 PM
Ironcross's Avatar
Ironcross
its a Shark and its lack of 'bling bling' compared to those other fishes that followed helps to make the 1968 special....
Old Aug 23, 2009 | 05:03 PM
CCrane65's Avatar
CCrane65
the wheel looks just like the one on a 67 but 67 or 68 wheels one should be rougher then the other. but I always forget which is which. but over 40 years the one that is suppose to be rough has wore off anyhow. or at least that is what s high up NCRS judge once told me
I bet the '68 wheel was rough. I had a '65 and it was smooth as glass. Looked like the swirl design in a bowling ball.
cc
Old Aug 23, 2009 | 05:11 PM
wildman378's Avatar
wildman378
Originally Posted by golfer9491
The carburetor is corvette only where other years they would be for camaros and chevelles as well as corvettes.
good point! the carb on my l36 is worth around 1500 bucks.....don't believe me look around and you'll see a decent core that needs restored sells for around 900 bucks.
Old Aug 23, 2009 | 06:32 PM
vettesbydesign's Avatar
vettesbydesign
steering wheel
telescoping column only
key on dash
door panels
shifter console
tach and speedo assemblies
shifter console shifter boot
RH dash w/ no map pocket
seat release location
radio *****
push button doors
mirror location
convertible top frame pins
tail lights
rear exhaust valance w/backup lights
front marker lights
front grills
front turn signals
front grill brackets
front bumper
hood support
327
bellhousing
carb
radiator support
frame
wiper door assembly door
vacuum canister for wiper door
fan
shroud
hood release cable on hood from side to side(white)
kick panels
interior rear light
seat material
7" wheels only of the C3s
no stingray script on body
gas tank
t-top chrome missing the holes
outer top of windshield moulding for conv. top pins
no side vent inserts
Old Aug 23, 2009 | 08:44 PM
CCrane65's Avatar
CCrane65
Not true about other year carburetors being shared with Camaros etc.
At least through '73 each engine had it's own specific model number.
Mine is a 7042217 and it runs around $1400-$1500 restored if you can find one.
cc
Old Aug 23, 2009 | 08:54 PM
wildman378's Avatar
wildman378
cc
What he said is true. For my 68 427/390hp 4sp there is only ONE carb which is 7028207 FG.
it was only put on a 68 427/390hp 4sp....NO OTHER CAR PERIOD.
where as the same engine option in 69 the carb was coded 7029215 which was used on other gm muscle cars like camaros, chevelles..68 was the ony year I know of to be that specfic on the carb.
Old Aug 23, 2009 | 10:30 PM
whitehause's Avatar
whitehause
Rear window latches and halo surrounds.
Old Aug 24, 2009 | 07:31 AM
emccomas's Avatar
emccomas
Not sure if anyone mentioned that early 68s have different size headlight assemblies than later 68 and up cars.
I don't recall the actual difference now, but I seem to remember that the early 68 headlight assembly (the headlight door that raises up) was bigger on early cars.
I think it was changed later in 68 to make the headlight opening smaller because of cracking between the headlight opening and the hood opening.
Old Aug 24, 2009 | 08:51 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...I was concerned about it being the "odd" year...
Nothing odd about my '68!! Everything about her is special.
Old Aug 24, 2009 | 11:40 AM
early shark's Avatar
early shark
How are these different from early '69's?
Old Aug 24, 2009 | 11:43 AM
early shark
Originally Posted by vettesbydesign
steering wheel
key on dash
door panels
shifter console
radio *****
push button doors
mirror location
tail lights
front marker lights
front grills
front turn signals
front bumper
hood support
327
bellhousing
carb
radiator support
frame
fan
shroud
kick panels
interior rear light
seat material
gas tank
How is vacuum canister for wiper door different from early '69? Same with front bumper?
Old Aug 24, 2009 | 02:33 PM
vettesbydesign
I'm not being a smart ***,but I don't play numbers.I have just had numerous 68s.I don't know when the cut off was,but the canisters are 68 only,and maybe,a few carried over to the real early 69s.The same w/the front bumper.The 68s have the rounded notches,and non of the 69s I have had have had them,and some were early run 69s.
I KNOW you know your stuff.I do cars,and parts.You know dates,and numbers,so they could very well have carried over into the first runs of the 69s.
Old Aug 24, 2009 | 02:34 PM
  #33
vettesbydesign
The early run 68s were actually a little smaller than the later run of the 68 models,and these continued onto 82.
Old Aug 24, 2009 | 03:12 PM
  #34
Easy Mike's Avatar
Easy Mike
...The early run 68s were actually a little smaller than the later run of the 68 models,and these continued onto 82....
That is correct as I understand it. I've read in a couple of sources that the '68 headlight doors/openings actually changed twice before the standard size was adopted. My AIM is from about May '68 and shows at least one running change prior to that.
Old Aug 24, 2009 | 04:25 PM
  #35
PRNDL's Avatar
PRNDL
re 68 corvette carburetor numbers and numbers for other year corvettes.
Here is a website I have been using for YEARS ! I believe their numbers are accurate.
http://www.blake.com/oemcarbs/chevy1.htm
Old Aug 24, 2009 | 05:44 PM
  #36
whitehause's Avatar
whitehause
The number of screws holding them on...halo's were wider to facilitate access to the screws. I beleive the shape was different also(square in 68)And yes they might have made a few 69's with the leftovers(till Nov 68 I believe), but I've always seen them advertised as 68 only, and they have a nice price tag to go with them.(yep....I broke one).
Are you asking because you don't know, or just to see if I know?
Maybe we should start a "what might have carried over to very early '69's" thread.
Old Aug 24, 2009 | 08:46 PM
  #37
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
....didn't see this mentioned, but it was the ONLY C3 with a telescoping "no tilt" column(optional to the standard column).
...the seat belt anchors/attachment assemblies were different.
...basket weave vinyl was one year only.
...'68 had a one year only master cylinder cap.
...'68 owner's manuals are unique to '68s.
To What Makes a '68 "Special"
Old Aug 24, 2009 | 09:30 PM
  #38
early shark
whitehause,
I actually didn't know, and wanted to learn.
Old Aug 24, 2009 | 09:49 PM
  #39
golfer9491's Avatar
golfer9491
got mine for $500 and it was stored perfectly just a quick rebuild and it is amazing.
Old Aug 24, 2009 | 09:53 PM
  #40
wildman378's Avatar
wildman378
nice find, hey u gotta pic of it? would like to see the cond of it for 500 bucks..thats a find!
where did u find it?
