79 vette Headlights
Old Aug 28, 2009 | 11:54 AM
bronco68's Avatar
bronco68
6th Gear
Default 79 vette Headlights
I am experiencing an issue with my headlights. all of a sudden they wouldn't come up when the switch was turned on. i can open them manually and they will stay on while running. if i pull the vacumn switch under the dash, they will stay up after engine is turned off. i pulled 25 inches of vacumn to the system and it will hold vacumn with engine off. where should i start. no vacumn leaks and everything works fine except coming up. the engine has 18 inches of vacumn at idle.
thanks
frustrated vette owner
Old Aug 28, 2009 | 12:51 PM
justaguy10825's Avatar
justaguy10825
Bad light switch???
Old Aug 28, 2009 | 01:11 PM
bronco68's Avatar
bronco68
6th Gear
Does the light switch have a trigger to control the headlights? Is there a relay that controls the up down?
Old Aug 28, 2009 | 02:05 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Yes. There is a vacuum line to the headlight switch. Pull the switch to turn on the lights and you send a vacuum signal to open the headlight doors.
The override under the dash bypasses the headlight switch and allows you to cycle the headlight doors a time or two with the engine off.
(I apologize for the original diagram. There are two of these available, an incorrect version and a correct one. I thought I had deleted the bad one, but --naturally-- deleted the good one.)
Old Aug 28, 2009 | 02:41 PM
bronco68's Avatar
bronco68
6th Gear
Thank you very much.
Old Aug 28, 2009 | 02:59 PM
...Roger...'s Avatar
...Roger...
Bronco the above vacuum diagram is wrong don't use it your headlights won't work correctly.
Old Aug 28, 2009 | 04:35 PM
bronco68's Avatar
bronco68
6th Gear
Default Thanks
Thank you for the heads up. i will trace thelines before i do any replacements.
Old Aug 28, 2009 | 04:38 PM
Peterbuilt's Avatar
Peterbuilt
Here's a corrected diagram. PG.
Old Aug 28, 2009 | 05:14 PM
bronco68's Avatar
bronco68
6th Gear
Thank you,
i see where the location of the lines are different at the headlight switch.
Old Aug 28, 2009 | 06:51 PM
Peterbuilt's Avatar
Peterbuilt
The troubleshooting guide at www.corvette-101.com/ is helpfull. PG.
Old Aug 28, 2009 | 06:58 PM
21boy's Avatar
21boy
You're lights turn on though when you pull your switch, just not up? Sounds like either the switch isn't holding well or perhaps the relays may have an issue???
To 79 vette Headlights
