Fuel Tank for 69
Old Aug 29, 2009 | 10:15 PM
Tony24's Avatar
Tony24
Default Fuel Tank for 69
I need to have my fuel tank repaired (leak under strap) or order a new one. If I buy a new one the catalog ask if I have a early or late model, how can I tell?
Old Aug 30, 2009 | 09:45 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Take the time/build code for your '69 (upper right corner of the trim tag), call the vender, give them the time/build code, and they should be able to tell you whether your car is early or late as it pertains to tanks.
Have you considered sealing the tank? If the hole is small, fuel tank sealant might solve your problem without the expense of a new tank.
Old Aug 30, 2009 | 09:49 AM
bojangies46's Avatar
bojangies46
Just buy a new tank and then you are done with it, not hard to change.--good luck.
Old Aug 30, 2009 | 10:23 AM
Alan 71's Avatar
Alan 71
Hi Tony,
The Quanta site indicates the change occurred with July-August built cars. It doesn't indicate what the change was, sorry.
Regards,
Alan
Old Aug 30, 2009 | 12:25 PM
Jeff_Keryk's Avatar
Jeff_Keryk
Perhaps you could ask about the differences and then look at your tank...
To Fuel Tank for 69
