71 L48 engine mods
Old Aug 31, 2009 | 02:57 PM
fgunnr's Avatar
fgunnr
Default 71 L48 engine mods
I have a '71 matching numbers coupe with the base 350/270 engine.
This is a sunny day driver and will never be a NCRS car as long as I own it.
What engine mods could I do that would not devalue the numbers matching engine.
I know about carb, headers, intake and such as long as I have the original parts that can go with the car. My concern is what happens with the addition of cams, pistons and such.
thanks
Old Aug 31, 2009 | 04:12 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You could rebuild to the 68-70 optional 350 hp version. It would look stock and most bystanders wouldn't know the difference.
Old Sep 2, 2009 | 07:29 AM
fgunnr's Avatar
fgunnr
What would this include?
Old Sep 2, 2009 | 08:14 AM
Easy Mike's Avatar
Easy Mike
Cam, valve covers, carburetor, possibly the intake. Any of the how to rebuild your small block Chevrolet reference books will have the specs for the 350/350 version.
Old Sep 2, 2009 | 07:42 PM
7T1vette's Avatar
7T1vette
If your car is basically "stock", anything you do to it that departs from a stock assembly will cost you money when you sell it. The best money you can spend to improve engine performance is to rebuild the carb and distributor, recurve the distributor per Lars Grimsrud's papers, and keep it well maintained. {Just my .02.....}
Old Sep 2, 2009 | 08:00 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
thanks
Bump for you. I am anxious to hear the answers to this one myself. I'll sit and listen. Thanks.
David
Old Sep 3, 2009 | 08:14 AM
Ganey's Avatar
Ganey
The hp gain for the 350hp is mainly cam, heads w/ larger valves & higher C/R.
When an engine is overhauled it is common to bore & replace pistons.
So you would use pistons that give a higher C/R.
68-72 standard hoods have limited clearance. One should consider the entire flow path.
The previous 2101 Performer & Chevy's bow tie intake are similar. Chevy has said it was as good as the high rise (LT-1). Chevy's bow tie logo & Edelbrock logo are behind the thermostat housing & not on the passenger side runner.
Cam- You should state trans.
Old Sep 3, 2009 | 03:02 PM
bobbarry's Avatar
bobbarry
I've got the same car and same engine, and the same dilemma.
At rebuild-time, I would recommend going to a 383 stroker kit, and porting the heads to complement a more modern-profile camshaft.
It would appear completely stock from the outside, but roughly double the hp of the stock engine.
To 71 L48 engine mods
