Quick Question Transmission cooling line fix
Old Sep 1, 2009 | 09:52 PM
enigma500's Avatar
enigma500
5th Gear
Default Quick Question Transmission cooling line fix
Just wanted to get an opinion.
The transmission cooling sprung a leak, well more like a shower.
It seems that where the transmission cooling line is clamped to the frame (near the rad), it has rusted away.
I've ordered new lines but they aren't going to show up for 3 weeks.
Would it be acceptable to cut away the rusted piece and replace it with the proper hose with clamps as a temporary fix?
Has anybody done this?
PS: My vette is a 1980 vintage
Thanks in Advance
Old Sep 1, 2009 | 09:58 PM
'75's Avatar
'75
Yes that will work, it's a good temporary fix.
Old Sep 1, 2009 | 10:28 PM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
Thanks in Advance
Yup that will work fine I did that to my old Grand Marquis as a temp fix probably 10 yrs ago! Im sure I even used fuel line
Old Sep 1, 2009 | 11:05 PM
enigma500's Avatar
enigma500
5th Gear
Thanks for the quick response guys.
I'll start on it tomorrow.
Didn't want the vette sitting around for 3 weeks.
Old Sep 1, 2009 | 11:58 PM
TimAT's Avatar
TimAT
Make sure it's tied so it won't get cut on anything. Don't forget- close to 100 PSI on that line too. Good clamps and double them up way back from the cut end of the hose.
Old Sep 2, 2009 | 08:11 AM
JimT's Avatar
JimT
I've done this on several cars. Use double clamps - good and tight, and secure the hose so it doesn'r rub on the frame. The fix will last forever.
Old Sep 2, 2009 | 12:47 PM
halfmoontrail's Avatar
halfmoontrail
Call Inline Tube, you'll have them in a couple of days...
Old Sep 2, 2009 | 06:39 PM
my 76 ray's Avatar
my 76 ray
As long as it's just temporary. It's one of those ask me how I know deals!
Old Sep 2, 2009 | 07:14 PM
7T1vette's Avatar
7T1vette
The hose needs to be rated for elevated pressures...probably good for 100 psi (cooler lines can see up to 40psi or so).
To Quick Question Transmission cooling line fix
