She started and ran for the first time in 20+ years
Old 09-23-2009, 02:19 AM
flyingman21
flyingman21's Avatar
Default She started and ran for the first time in 20+ years
I still can't believe the day finally came. After taking over this project about 6 months ago it has been a trip. I have never done anything like this, neither has my credit card. I have learned lots, okay everything from this forum
The break-in went uneventful, I made a sacrifice to the Corvette gods that morning.
For the set up I set the initial timing around 10, but you see us messing around with it during cranking. After we got it running it was set at 38*.
For the fuel I got my hands on some 100LL, she liked that
For the oil I used Joe Gibbs BR30 Break-in oil + Comp cams oil additive. I have sent out the oil to Blackstone and will post the results.
I ran distilled water in the radiator just in case. As you can see in the video the radiator had a 100 degrees drop across it. The DeWitts and dual Spals kick A$$!!!
I ran Moroso Ultra 40 wires and NGK V-power plugs.
The headers were on there just for the break in because I have decided to put the ram horns back on.
I had 2 shut downs during the break-in. The first one due to the water temp gauge being pegged, even though the IR gun said things were okay I decided to be on the safe side. The problem was the gauge cluster not being grounded The second one because I forgot to put fluid in the power steering pump, I hope I didn't burn it up.
The next day I bled the brakes in the new SS system. No problems or leaks
Next on the list is the drive shaft and a wind shield so I can finally go drive it
BEFORE
DURING
BREAK-IN VIDEO
Old 09-23-2009, 08:41 AM
bobs77vet
bobs77vet's Avatar
Location: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
good job
Old 09-23-2009, 09:16 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,470 Likes on 1,249 Posts
Cruise-In II Veteran
Congrats. Feels good, huh?
Old 09-23-2009, 08:44 PM
wnmech
wnmech's Avatar
Looks good and sounds even better
Old 09-23-2009, 09:14 PM
dbeall1968
dbeall1968's Avatar
That is a great feeling when they come to life for the first time. I was cringing when it was cranking and you had your arm over the carb. I have seen some nasty backfires, and you were in the right place for a bar-b-que. I am glad it worked out. Great job so far, Nice radiator set-up!!
Old 09-23-2009, 09:16 PM
Low12s
Low12s's Avatar
Location: Life isn't about waiting for the Storm to pass, it's about learning to dance in the Rain.
Nice
Old 09-24-2009, 01:14 PM
bobbarry
bobbarry's Avatar
I like that engine, but I LOVE that exterior color!
Old 09-24-2009, 04:33 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi FM21,
I enjoyed your pictures and video.
Pretty special day for the car and for you!!!!
Regards,
Alan
Old 09-24-2009, 05:52 PM
clay9_24
clay9_24's Avatar
Looks fantastic! I would give anything to have that kind of space in my garage to work with
Old 09-24-2009, 10:22 PM
OMF
OMF's Avatar
Thats always a good feeling when you start a new mill....
Old 09-24-2009, 10:28 PM
400hp427vette
400hp427vette's Avatar
St. Jude Donor '09
Must feel great, Congrats on the build.
Old 09-24-2009, 11:40 PM
rajsid
rajsid's Avatar
Congrats!!!
Old 09-25-2009, 01:48 AM
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
Douglas Mariani's Avatar
Congrats
Old 09-25-2009, 05:55 PM
Dustup7T2
Terrorizing Orange Cones
Dustup7T2's Avatar
That first time is always exciting. Congrats!
Old 09-25-2009, 06:01 PM
Corey_68
Corey_68's Avatar
Nice
Old 09-25-2009, 08:41 PM
flyingman21
Thanks guys!!!
I am fortunate to have a great hobby shop on base where I am stationed. They only charge 8 bucks a days and I can use all the tools they have. That wasn't me checking for a back fire I was inside cranking it up.
As far as the color I call it hippy camouflage. I still haven't decided on a final color. I am torn between the original color (Fathom green) or a color I really like (fathom blue)!
Old 09-25-2009, 09:01 PM
OURSHARK
OURSHARK's Avatar
Congrats, its a great feeling when they come back to life.
Old 10-18-2009, 11:53 PM
flyingman21
As promised the oil analysis from the break-in. The lead was from running 100LL ( I hope anyway ) The Zn and Ph were really high due to running the Joe Gibbs Break-In Oil and a bottle of Comp Cams break-in additive
Will post the one at 500 miles ( If I ever get there)
Old 10-19-2009, 12:24 AM
orourke
orourke's Avatar
The memories of the long hours at the Base Auto Hobby Shop. I couldn't have built my stuff without it. S.O.A.P Samples to boot!
9 on your EPR!
Marty.
To She started and ran for the first time in 20+ years
Quick Reply: She started and ran for the first time in 20+ years
