Late Production 70...any differences
Old Sep 26, 2009 | 08:57 AM
exposingtime's Avatar
exposingtime
2015 C3 of the Year Finalist
Default Late Production 70...any differences
I seem to recall reading at some point that there were a few differences between the late Production 70's...basically some 71 styling features.
Possibly the grills, etc.
Any help?
Old Sep 26, 2009 | 09:05 AM
GD70's Avatar
GD70
Any help?
Grills possibly may have changed late to using 3 screws instead of just one. I know some of the later L-46's had a closed dual snorkel air cleaner. The ignition shielding box design also changed. There may be other subtle changes I'm unaware of and others I'm sure will chime in.
Glenn
Old Sep 26, 2009 | 09:08 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The 70-72 NCRS Judging Manual says 70s after #13656 got the '71 grilles with two mounting screws in the lower rail. No screws prior to that.
Old Sep 26, 2009 | 09:11 AM
GD70's Avatar
GD70
Thanks for setting me straight on that.
Glenn
Old Sep 26, 2009 | 10:10 AM
Alan 71's Avatar
Alan 71
Hi ET,
A couple more 'late' changes....
A slight difference in the construction (the weld) in the exhaust tips.
A change in the LT-! hood stripe from unequal width lines to equal width lines.
Regards,
Alan
Old Sep 26, 2009 | 10:11 PM
Solid LT1's Avatar
Solid LT1
Side eggcrate grilles have raised chrome trim where early 70's have flat edges. I know of a 70 that seems to have one early front grille (no lower mounting screws) and a later driver's side grille. The car in question is a 14XXX series car and was close to end of 70 production run.
Old Sep 27, 2009 | 08:19 PM
lakensea's Avatar
lakensea
I have a late (15123) and it has the later grill on the driver's side also - I always thought it had been damaged and replaced with a service replacement grill.
To Late Production 70...any differences
