engine pad stamp
From what I could find on it
T stands for Tonawanda (plant location)
09 is the month
23 is the day
and ckb can be any of these 3:
1972 350 tur 400 trans. L65 165 2 A B
1973 350 m/t, 4 spd L48 175 4 F AX/Monte
1974 350 m/t, 3 & 4 spd 185 4 F X
I have a 1972 and the previous owner (who isnt the original owner) said the engine and trans had been swapped before he bought the car. He tells me it now has the turbo 400 trans and 350 engine. I think it had manual originally because it looks like a clutch pedal is still there but cut off with a hack saw which is another item I need opinions on
Im just curious about what I'm missing here, I thought the pad included a partial VIN and info on what car the engine originally came in. Here is a picture of the pad I'm looking at, maybe I am looking in the wrong place, I admit to being a complete newb with this
Thanks for any help you can give me!
The notes I have here at work only go up to 1972, and I don't show an engine suffix for "CKB" for that year, or any other year from '68-'72.
To say any more would be guessing, so I'll stop here and wait for the more informed to help you further. Good luck!
Clean off the engine pad next to the 8 you found. There may be a VIN derivitive stamped there. The 8 might be a part of it.
I agree, it looks like a former clutch pedal arm has been sawed off. Check your frame at the left rear of the engine block to determine if a factory clutch bracket is/was there.
Given the above, we can conclude that what you have is not a Corvette engine. That isn't terrible, but the Corvette engines of the era generally had a few more ponies than the general service replacement engines.
In all my life, I have never seen a pedal cluster in a car with the clutch pedal cut off. Bubba was definitely there.
Good luck!
PK
The vin derivative, assuming it is on the engine, may be stamped on the side of the block near the oil filter boss. Some 69 Z/28 engines were like that. Otherwise, don't have a clue.
I'm also hoping to pick up a decent manual tranny at a swap meet next year. I noticed the wide brake pedal and just figured the person picked it up along with the center console made for the automatic shifter, you know, the center console that's held together with silver sheet metal screws...
I'll get out and check on a few things from stuff you guys have told me. One thing, is that I'm pretty sure there isn't another number next to the number in the pic. I cleaned on the pad for a while and nothing came out.
I took digital pictures of my DZ302 then zoomed in and was just able to make out the numbers.
tom...
