Engine Suffix help
Thanks!
0207 is assembly date (February 7th)
HC is engine suffix code. Possilities are:
1965 327, 250 hp, 4bbl, PG in a pass car
1966 327, 275 hp, 4 bbl, PG in a pass car
The last H tells us that the engine had a Holley carb. Based on that, it is most likely a 66 327, 275 hp, Holley 4 bbl, PG, in a pass car.
HCR code would have meant it had a Rochester carb.
VIN derivatives were not consistently stamped on passenger cars until the late 60s.
