painting question
Old Oct 3, 2009 | 09:24 AM
riarms's Avatar
riarms
Default painting question
I will very soon painting the plastic seat buckets and a few other plastic parts from my 81.
Whats the best way to do this. I have the die/paint. should i sand and prime, or just clean and then apply the die?
Old Oct 3, 2009 | 09:31 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Die is for vinyl. NOT Plastic, clean them really good, prep them and spray them.
I just finshed my buckets they came out very nice,
When you spray them only apply a thin coat of paint,
you don't want it thick and blending over the texture/ grain of the plastic.
Do not prime, that will in all the texture/grain area's.
69VETT
Old Oct 3, 2009 | 10:12 AM
spedaleden's Avatar
spedaleden
When I shot my plastic parts there are three things you need, so the dye sticks and does not peel.
Step 1 Plastic Primer Mid-America 106-131 or 106-133
Step 2 Your spray Dye
Step 3 Final touch I used low luster this protects the dye from being scrathed off. They also make it in high gloss.
I would also try Wilcox
Old Oct 3, 2009 | 06:41 PM
riarms's Avatar
riarms
I got the die/paint from Wilcox. was the vinal touch a clear?
Old Oct 3, 2009 | 10:21 PM
spedaleden's Avatar
spedaleden
Yes
Old Oct 4, 2009 | 10:33 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
SEM automotive interior dye will cover vinyl, leather, and plastic. Any surface to be dyed must be squeaky clean.
Old Oct 4, 2009 | 11:20 AM
Paul L's Avatar
Paul L
Use isopropyl (rubbing) alcohol for cleaning.
This is where I use paint.
On vinyl I use dye. I picked up a set of nice door panels on EBay last year in red. I needed oxblood.
Dyed this...
...to this.
Old Oct 4, 2009 | 11:17 PM
7T1vette's Avatar
7T1vette
Vinyl dye is made for most plastic & vinyl surfaces; it works on leather too. All surfaces must be free of contaminants....including PAINT!
Old Oct 6, 2009 | 10:12 AM
riarms's Avatar
riarms
thanks for all the help. I just cleaned them real good with denatured alcohol. the trick was getting it to spray even. took me a couple times. I went to light the first time and it came out very dull. I found what worked best for me was spraying the buckets just so they looked wet and it had a nice shine to it after they dried.
To painting question
