rear spring
Old Oct 9, 2009 | 11:46 AM
gjohnson's Avatar
gjohnson
Default rear spring
What yrs are the steel rear spring interchangable. I have a '76 . Found a '79 being parted w/ a new steel spring. Will it fit? Thanks
Old Oct 9, 2009 | 01:37 PM
crvtownr's Avatar
crvtownr
I took a look at a couple vendors and they list the standard leaf springs as 63-77 and 78-82, but I am not sure what the difference is.
Old Oct 9, 2009 | 01:47 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by crvtownr
...but I am not sure what the difference is.
Width of the spring, I believe.
Old Oct 9, 2009 | 01:50 PM
Ganey's Avatar
Ganey
The width changed during 78 from 2 1/4" 63-77 & some 78 to 2 1/2". The 78-79 were heavier.
Old Oct 9, 2009 | 01:51 PM
...Roger...'s Avatar
...Roger...
Depending on the width of the new spring on the 79. If its 2 1/4 it will fit but if its 2 1/2 "AND" you still have the older design diff cover with the large diameter bolts it will not.
So you need to know if your rear cover has been changed to the smaller bolt design and what the new spring width is.
Old Oct 9, 2009 | 09:50 PM
gjohnson's Avatar
gjohnson
Thanks for the replys. I will check the diminsions.
Old Oct 11, 2009 | 01:33 PM
gjohnson's Avatar
gjohnson
I checked and I have the older style cover.Are the covers interchangable? If so I'll get the cover also.Should fit then,right? Thanks
To rear spring
