Starter suggestions ? (74 454)
Old Oct 18, 2009 | 08:22 PM
johnmb's Avatar
johnmb
Default Starter suggestions ? (74 454)
I'm in need of a starter for my BB 74. It's got a moderate compression 454 / cam etc, so I'm wondering if there's any suggestions on an appropriate starter. When the OEM version was working, it never turned the engine over very fast.
The car has Hooker side pipes which actually seem to improve access to the starter, though this may be wishful thinking :-0)
Any ideas on a good starter? Money is an object but not the only one... would I be better off sticking with the OEM ?
John
Old Oct 18, 2009 | 08:50 PM
Grumpy 427's Avatar
Grumpy 427
Nothing wrong with a stock GM high torque starter.
Old Oct 19, 2009 | 04:30 PM
Ironcross's Avatar
Ironcross
Good advice above, Or if originality is not important the small gear reduction GM starter for late 350`s and 454`s is another choice except it is a Metric starter and requires a different set of bolts from early 454`s to late 454`s which they do have available. All stock stuff and either one will work just fine...
Old Oct 20, 2009 | 09:08 AM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
This comes up a lot. The stock starter is just fine, but ALL of the connections have to be in good shape or you will have problems. I had the "slow turner" problem when I bought my car last year, and the problem turned out to be some boogered threads on the solenoid causing so-so connections. I spent $15 on a brand new solenoid (available at the local auto part store), and the problem disappeared.
Old Oct 21, 2009 | 04:58 PM
johnmb's Avatar
johnmb
Any of the aftermarket (Summit, etc) mini-starters worth a look?
Old Oct 21, 2009 | 05:24 PM
DRIVESHAFT's Avatar
DRIVESHAFT
This is what is spinning the 454 in my car.
http://cgi.ebay.com/ebaymotors/Chevy...Q5fAccessories
After I got the correct bolts it has worked great.
Old Oct 21, 2009 | 08:13 PM
johnmb's Avatar
johnmb
Default Bolts?
Did they forget them, or did the stock ones not work with this new starter?
Old Oct 21, 2009 | 09:19 PM
DRIVESHAFT's Avatar
DRIVESHAFT
The bolts they supplied didnt fit the starter correctly. They seemed like they were correct, but I couldnt shim the starter anywhere that would stop it from grinding. They supplied bolts were apparently letting the starter twist under load. After a reading thread here about the subject, I bought the correct bolts from a Chevy dealer. After replacing them I havent had any trouble.
Old Oct 21, 2009 | 09:26 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
get your original rebuilt/ restored
Old Oct 21, 2009 | 09:43 PM
SteveG75's Avatar
SteveG75
GM part #9000852 is a late model truck starter. It is designed for big blocks with a 14" flexplate. It also fits any BB with a 14" flywheel. Any good parts store should be able to reference the GM part # to get you a starter.
One note. You cannot use your stock bolts. The correct bolts are special with metric shanks and standard threads. GM part# for the bolts is 12338064 and you can get them from any dealer. I also modified an old starter brace, but it is not really necessary.
I have been using that starter for a couple of years and it works great. Good enough for the ZZ502, good enough for me.
Link with more info here:
http://forums.corvetteforum.com/c3-g...n-a-454-a.html
Old Oct 21, 2009 | 10:49 PM
79 vette head's Avatar
79 vette head
St. Jude Donor '10
thats what i just got
Old Oct 24, 2009 | 08:02 PM
johnmb's Avatar
johnmb
Default Success
Installed the mini starter that was kindly linked to, using the GM bolts and all is well. Man does that tiny little thing crank the engine...I'm amazed.
Thanks for the tips on the bolts. The local dealer had 'em and even though the ones that came with the starter LOOK the same , they're not the same dimensionally.
This is a great forum...
John
Old Oct 24, 2009 | 08:18 PM
zwede's Avatar
zwede
I've been running that late model Delco starter for years and it's a wonderful little thing. About 8lbs but spins my 10:1 454 like nothing.
To Starter suggestions ? (74 454)
