Shifter Knob
Old Oct 21, 2009 | 12:29 PM
dburgjohn's Avatar
dburgjohn
Default Shifter ****
My 81 has the wood kit including the shifter ****. when it is in the drive position, you can see a gap under the button (I know I am OCD). Does the stock ***** do this or is mine in need of adjustment?
Old Oct 21, 2009 | 01:18 PM
MakoShark72's Avatar
MakoShark72
Dont both screw on? They do on my 72... I might just screw "up" the **** and screw "down" the button until the gap goes away. A little loctite to hold them in place??
Dont know about the 81, but might work...
Rob
Old Oct 21, 2009 | 03:09 PM
dburgjohn's Avatar
dburgjohn
Did have that thought. Button is all the way down and if I raise the ball, the threads show and that is sort of ugly.
Rob
Old Oct 21, 2009 | 10:17 PM
Alex/plus's Avatar
Alex/plus
Don't put up with those nasty threads showing, wrap some duct tape around that stick.
Old Oct 21, 2009 | 10:32 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Yes both screw on and no when you install the factory ***** there should not be a gap showing.
I guess if you wanted your current **** to work with what you have you could cut some of the shaft off that the button screws down on. I don't think I would do this though.
Willcox
Old Oct 22, 2009 | 12:06 AM
fugawi's Avatar
fugawi
what about a jamb nut at the bottom of the ****. that would raise the **** just the right amount to hide the gap..
To Shifter Knob
