Fall Winter projects thread
Old Oct 22, 2009 | 06:57 PM
Gordonm's Avatar
Gordonm
Default Fall Winter projects thread
Binnie77 post on his project got me thinking about what I have to do this winter. I have to finish up a body on resto for another forum members 77 car. We already installed a new crate motor and 5 speed. Completly reworked both front and rear suspension with some Vb stuff. He shipped the car down to me to finish the Dewitts install, hydroboost, Steeroids, brakes etc. and all the new wiring plus the dash and about a million other small details. Finally fire it up and make sure it is all roadworthy. That should be enough, but noooo! I am going to yank the motor and trans in my car and put in a solid roller cam and just go through the motor. Also have some better shifter lugs for my Tremec trans. I also bought a set of double offset trailing arms for mine. Then I have another forum members car that he has a dual mount spring to install and a set of double offset trailing arms also. This should keep me busy for the fall/winter months.
What is everyone else doing.
Old Oct 22, 2009 | 07:53 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Nothing on the car. Too damm cold in the garage. Helll that's no excuse, I haven't done anything on the car since I got it running right about 2 years ago.
Getting my snow blower ready for global warming though.
Old Oct 22, 2009 | 08:01 PM
Jclgodale3's Avatar
Jclgodale3
Complete front and rear suspension rebuild on the 68. Parts are here and the tear down has begun
Old Oct 22, 2009 | 08:23 PM
Tom's 79's Avatar
Tom's 79
This winter I may try rebuilding my turbo 350 trans. Never rebuilt a trans before but I'm reading up on it now. First I am going to take some pressure readings from the trans and see what the readings are. If they are out of whack I will do the rebuild. Trans feels like it is slipping during 1/2 to 3/4 throttle upshifts, taking way too long to get into next gear. I will put the tougher sprag gear in it, extra clutch plates and a shift kit while I have it apart. Wish I could just buy a reman 200r4 but I have to watch the cash. Have alot of time and not alot of cash right now.
Old Oct 22, 2009 | 08:36 PM
The13Bats's Avatar
The13Bats
Gordonm,
You might be sorry you asked,
I am in FL and that means winter doesn't slow me down in fact the cooler weather is great for me I don't do well in heat,
Bats don't like direct sunlight,
I have too much yard art,
While I am big into early kit cars Vettes are my real love,
My goal for the new year is to only have the Mako vette project and my vw trike,
I don't want to jinx it but I believe I found my Mako project donor,
No engine, so that means scoring a BB and I am guessing a 502 this time.
Mike will pull molds off my mako parts so I have extras to fall back on and don't ruin the original parts for my build,
Off topic of vettes but on the whole project thing, I am hoping before new years to have this thing , my red stink bug all wired up and running so I can get it out there and get it sold,
And I still have a mid engine 327 chassis and early GT40 body to get moving out...
So yes lots of activity in the Bats Cave
Old Oct 22, 2009 | 08:42 PM
Sebago Shark's Avatar
Sebago Shark
St. Jude Donor '09
Rear wheel bearings and TA's on my Silver Ann.
On the Pace Car I'd like to do something to make a PO's black repaint look better, if possible without repainting. Someone did a pretty crappy job on the hood and front fenders. You can see the old spider cracks and sanding marks through the paint.
Oh yeah, almost forgot, maybe I'll finish the '41 pickup I've had since high school this winter.
Got plenty of time up here before the roads are cleaned up, unfortunately.
Old Oct 22, 2009 | 10:37 PM
73sbvert's Avatar
73sbvert
Crackin' on...
St. Jude Donor '09
Finish the &^%$# steering install, front suspension, new seats, top end of motor.
That should keep me busy!
Old Oct 22, 2009 | 10:43 PM
jbaron's Avatar
jbaron
2017 C3 of the Year Finalist
My winter project isn't really mine...
Just dropped it off for paint!!! Stopped in today it's already being torn down.
Old Oct 22, 2009 | 10:55 PM
01BoostedZ's Avatar
01BoostedZ
My fall/winter project consists of a 496 swap. The small block factory sidepipes will be replaced with Stahl headers and sidepipes. A Dewitts radiator and fans, along with an L88 hood is also on the list. If I can scrape up enough cash, I will also be adding a 5-speed.
Old Oct 23, 2009 | 12:02 AM
vettenoir's Avatar
vettenoir
Finish up the spring/summer project:
New 409ci solid roller motor (hopefully fire it up this weekend!)
DragVette 6-link
Steeroids
Hydroboost
Wilwood brakes & aluminum hat rotors
Billet Specialties wheels /w Kumho XS's
Maybe a 2004R in place of the Turbo350???
Old Oct 23, 2009 | 12:20 AM
MN80Vette's Avatar
MN80Vette
I plan to replace body mounts this winter (groan....). I live in Minnesota but have a forced-air wood-burning furnace in a 28x48 garage with a 4-post lift, a stereo, and a well-stocked fridge.
Old Oct 23, 2009 | 07:21 AM
Gordonm's Avatar
Gordonm
AHHH heat. It sure is nice. I installed a small heater in my garage last winter. Sure makes it nice to work in. I like it about 60 to 65. Takes about 15 minutes to get up to temperature.
Old Oct 23, 2009 | 08:19 AM
panic's Avatar
panic
My projects for this winter...(...anyway I need to recover from my daily driver crash pocket and body disruptions first...)
1) Dump the 50lbs vacuum steel tube...arriving to around 2.700lbs weight.
2) Front/rear coilover suspensions.
3) Rack and pinion steering.
Old Oct 23, 2009 | 08:21 AM
Jeffery73's Avatar
Jeffery73
St. Jude Donor '08-'09-'10-'11-'12-'13
I don't have much to do to the Vette this year. I will spend quite a bit of time working on these.
Old Oct 23, 2009 | 08:39 AM
hwcoop's Avatar
hwcoop
going to be a busy winter...
doing the Rocker channels on my friends 72 restomod...383, 5spd, C4 suspension, new frame. he wants it on the road for June.
On mine I need to pull the trans and change the tailshaft bushing,yoke and hopefully swap heads & do a rebuild on my carb with new bushings etc.. good thing we have long winters here
Old Oct 23, 2009 | 09:48 AM
John D.'s Avatar
John D.
Replacing heater core and interior carpeting in the 71.
Old Oct 23, 2009 | 10:00 AM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
I have a long list of knick knack kind of things that I have already started knocking out when the weather is bad on the weekends. It is supposed to rain tomorrow, and my son told me yesterday he wants to help me fix the door pull on the passenger's side, so that will be done before storage. I also only need to paint the Y-strap and I can install the spare tire stuff (jack and wrench are already in). Bunches of stuff like that. The only thing that I think will turn into a project is that I know I have a vacuum leak, and I can't get any air flow out of the dash vents anymore, so I get the feeling I am going to be taking a substantive amount of the dash apart to get at the HVAC box and figure out what has gone awry there. I never took the dash apart on any of my old cars that weren't VWs (and VW dash boards are remarkably simple), so I assume that will be an adventure to remember.
To Fall Winter projects thread
Old Oct 23, 2009 | 10:04 AM
Derrick Reynolds
If you have a non-AC car, I think it was GD70 that very recently put together an excellent post with great pictures on how he changed his heater core from the engine side. If you do have AC, Paul74 has posted pictures and experiences on changing it from inside the car as well. Highly recommended viewing/reading!
Old Oct 23, 2009 | 10:12 AM
greg75vette's Avatar
greg75vette
Hopefully get a lot more done with my LS1/T56 swap. No garage makes for a very cold work day
Old Oct 23, 2009 | 10:15 AM
GPGG70's Avatar
GPGG70
Hi Gordon,
I've allready started many projects on my coupe but have a lot of while I'm at it projects. It's a body on project at this point in time.
Starting with,
Pulled the heater core and had the original rebuilt along with the radiator but have installed a nice Dewitt rad in it's place.
Replaced the interior firewall insulation
Pulled the evaporator & housing and cleaned out all the debris.
Pulled the exhaust manifolds and starter to clean & paint the block and pan. Getting ready to start putting everything back together today.
Will continue to prep & paint the frame back to the rear wheel kickup's then install the new sidepipes.
If I'm lucky I'll have the car to this point by the end of next week, but more like the first week of november. Sometime then I'll pull the steering assy off the car and rebuild then re-install, then continue on the assend of the car. Having a blast working on these cars.
