Weatherstrip replacement started-PICs, observations, a question.
When I thought about it, I have never seen this issue mentioned in any of the interior restoration threads. This must be an unusual issue.
Glenn
I finished both rear side ws and moved on to the left front WS which was a mess. Bubba spliced a replacement section as the pics show, but left the top. I got it all removed except for the lower extension. I'll post more pics as I proceed.
Halo & receptor hole in the bird cage.
Front WS
Glenn
I am so glad you are posting this stuff! I am just about to start this project ... gotta remove the old before the new paint job is started then will put the new stuff from Willcox on... keep the great pics coming!
Sully
Starting clean after the paint will make it easy to apply the WS's. The 3M ws glue starts to skin over within seconds of applying it to the part surface, so pre fit everything so you know how it fits and can move quickly when you start gluing.
Glenn
I used a new screw kit and black Goop (incorrect I know but one of my favourite products) to seal under the SS trim.
The whiteish powder is SS metal polish and GM silicone emulsion. This was tidied up later as you can see in my first pic.
Glenn
That's where I hope to be tomorrow. The CRC WS's are very nice. After the A pillars are finished, on to the doors.
Glenn
Glenn
I started at the bottom of the WS. Put the screws in place on the ws before you glue it to the base of the windshield. I used a lot of adhesive and covered all the bare metal to make sure it would be sealed well. The front most screw is a royal PITA to get at, as you need a very short philips screw driver, or as I did used my Swiss Army knife with the screw driver open at a 90 degree angle to fit in there. After that section is in place, I then glued the rest of the ws and retainer and used a plastic putty knife from Home depot. Sand the corners round and dull the blade so it doesn't cut into the ws when you are pressing it in. I put the rear edge in first, then used the putty knife to tuck in the front edge. You must work quickly as the glue starts to dry very quickly.
The base area.
The ws installed.
I'll need to adjust the side window so it seals against the side rear ws, there's about a 1/16th gap now.
On to the right side soon.
What is the purpose of the blowout clip? It seems that the adhesive would be sufficient to hold the ws in place. Mine also looks a bit too tight & pinching the ws too much compared to Paul74's ws.
Glenn
My understanding is that the clip is there to prevent the side window from being sucked out at HIGH speed. It's one of those things that the car seems to be able to do without but you know it wouldn't be there if Chevrolet didn't think it was necessary.
Regards,
Alan
Regards,
Alan
I'm not seeing how this would work, being that it does not physically clip onto the glass, but sits under it.
Glenn
Looks nice!!!
I think that the clip actually helps keep the glass from riding to far inward when rolling it up. The glass makes light contact with the clip while rolling it up. It also keeps the WS centered and inplace when the glass is down.
From your pictures it looks like it is pinching the WS pretty tightly -
I don't remember mine being like that. I will take a picture for you tomorrow AM and post it. Be really sure the WS in stuffed all the way in the chanels and is completely flush on the back with the stainless trim.
Looks nice!!!
Thanks! It does look like it's pinching the ws too tight and will try to bend it out a bit. The ws is tucked in the retainer strip and fit like a glove! I wish the 3M adhesive had a bit more working time though. You have to move quickly once it's applied!
Glenn
I've always wondered what the purpose of that clip is as it's been on every GM 69 & up vintage car I've owned or have seen.
I always appreciate your input.
Glenn
Edit: I bent out the clip this morning and much better & not pinched. I'll need to adjust the side window for now and readjust once I get the T-top ws's. Meanwhile I'll replace the right side A pillar ws, which is in pretty good shape, but want it to match the left side. Then on to the doors.
The old ws was in decent shape, but wanted it to match the new ws on the left side.
You can see it wasn't very well blended to the extension.
It's a real PITA getting at the front screw and had to use my trusty Swiss Army knife to get at it.
I cleaned all the old adhesive an repainted the birdcage surface.
Here's the new ws in place. I needed to tape it in a few places until the ws adhesive was fully cured.
This is important: Screw in the PITA front screw almost completely in BEFORE you put the adhesive on the surfaces. Set the second screw in place on the ws. Let the ws pivot down on the front screw and now add the adhesive, then quickly move up into the correct position and screw in the second screw tight, then go back and tighten the front screw. Then get the 3rd screw in place, add adhesive and screw it in. Then finish the upper A pillar section.
And here it is completed.
My one complaint is that the 3M adhesive dries way too quickly and had to reapply some in a few spots.
Next will be the driver door.
Glenn
